Thread: Denford Mirac conversion help
Thanks for taking the time to reply, I would love to do servos with a closed loop if possible. But I am not sure if it is feasible or necessary. Time is my enemy, I spend 7 days a week working which only leaves a few nights for this.
there doesn't seem to be to many places in the uk to purchase the hardware I need.
what I do know, the turret is probably going to give me some grief setting up and the encoder on the spindle is going to be another pain.
The pdmx boards seem a good option as they can plug into each other with ribbon cables etc, but USA supplier. I guess there is no recommended setup, I guess I just want a no nonsense setup.
21-10-2016 #2
Are the present moment only Kflop, and pokeys can thread inside Mach and for Pokeys it's mach4. Both are a work in progress, a long work IMHO.
Planet CNC can thread but it would be hard to do turret.
Possibly you best bet is Linux CNC but you will need a LOT of help.John S -
The Following User Says Thank You to John S For This Useful Post:
21-10-2016 #3
I've just had a look at the Mirac lathe specs and realised potentially what turret it comes with.
If it is a Barafuldi TOE80, then you will not be able to control the turret directly via a Mach 3 macro, Mach 4 might just about manage the timing, but I wouldn't be 100% sure about that, as the timing requirements for the turret require fast responses to inputs/outputs.
Something like a KFlop could, as you can programme the KFlop directly to handle the toolchange, and Mach3 would simply command the KFlop to carry out the tool change.
The other option is to use a PLC to handle the tool change (I used a Click PLC, and you're welcome to the code if you choose that option).
One thing I should mention, is that even although KMotionCNC does everything I need it to in terms of running my lathe, I do miss the wizards in Mach 3. However, if you have a Mach3 license, most of the code will work, it's just canned cycles where things generally won't.
Personally, given the Mirac will most likely use 12 or 24V control circuitry already, I'd be looking at something from CS-Labs, or a KFlop+Konnect(IO board)(+Kanalog if you want to run analogue servos with the KFlop closing the loop).
Smoothstepper/Pokeys only work on 5V.
I can't comment on PlanetCNC, but there are suitable MESA boards available for LinuxCNC, but as John says, help can be very hit or miss.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
21-10-2016 #4
Hellfire: I also own a Denford Mirac, but mine does not have the ATC.
Does your Mirac use the newer control board or the older LCB3?
Mine uses the LCB3, and I am using a Ethernet Smoothstepper in combination with the LCB3.
Best Regards."If first you don't succeed, redefine success"
The Following User Says Thank You to Mad Professor For This Useful Post:
21-10-2016 #5
Thanks guys, I think it is a Barafuldi TOE80 turret.
Regarding the turret, would it be possible to use the positional switch inside for indexing
21-10-2016 #6
Smooth stepper can't thread yet either, It was promised 4 years ago mind you .........................
John S -
21-10-2016 #7
If you go to the Denford forums (www.denfordata.com/bb), you can download the TOE80 manual in the Mirac section (it's also in the Cyclone section).
It gives all the details for inputs/outputs and the required timings.
John, the Smoothstepper can do threading using a single slot sensor as I used it on my old Conect lathe.
It's encoder threading that still hadn't been implemented the last I checked. I suspect the real reason for the lack of progress is the physical hardware doesn't have the capacity to implement it. I know the last discussion I seen about it, Greg was talking about optimising/freeing up resources, so I think it's another case of underestimating the hardware requirements, aka Gecko GREX and various others.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
22-10-2016 #8
23-10-2016 #9
Came across these, are they worth having.
https://www.cnc4you.co.uk/Stepper-Mo...or-8Nm-Nema-34
25-10-2016 #10
Closed loop steppers are one possible option, and are a pretty good compromise between the existing standard (open loop) stepper motors, and a proper servo system.
Whats it worth, Denford Mirac CNC Lathe
By Dean jeffery in forum Marketplace DiscussionReplies: 4Last Post: 03-07-2014, 01:38 PM -
FOR SALE: Denford MIRAC CNC Lathe. Single Phase. Absolutely complete and perfect running order.
By Nick Butler in forum Items For SaleReplies: 19Last Post: 21-08-2013, 11:20 PM -
FOR SALE: Denford Mirac CNC Lathe with Auto Tool Changer For Sale
By CHudson in forum Items For SaleReplies: 3Last Post: 19-02-2011, 12:11 AM -
RFQ: Looking for somone to finish conversion Denford Mirac with Mach3
By CHudson in forum Projects, Jobs & RequestsReplies: 0Last Post: 14-10-2010, 08:20 PM -
Denford Mirac Electronics Refurbishment
By CHudson in forum Computer SoftwareReplies: 11Last Post: 17-06-2010, 08:30 PM
