  1. #31
    Say what with the who now!? There are always wheels within wheels with this hobby. How do I pierce at a slope!?
  2. #32
    Your slot drill is bound to chew up the metal directly below it's centre, it is just something they do. A milling cutter has no cut towards the middle so it can leave a fine finish below. They all have their tricks.
    However a milling cutter can only plunge vertically so far before it's non-cutting middle bottoms out, so you have to move sideways as you move downwards to remove that middle.
    Well, either that or restrict your Z travel to what it can manage
  3. #33
    Ah, I always climb into the cut so I should be able to end-mill. But I thought a slot-mill and an end-mill were essentially the same things these days? How would I know I was buying a true end-mill that gave me a smooth bottom. So to speak.
  4. #34
    You "pierce at a slope" by using the ramped or spiral lead-in options in your CAM package.
    Clods have muddied the water on cutter nomenclature but there are always centre-cutting and non centre-cutting tools, Slot Drill used to refer to a centre-cutting tool capable of plunging (Drilling) and End Mill to a non centre cutting tool,
    - Nick
  5. #35
    Ah, Ok, so I want a non centre-cutting mill to achieve a good finish on my bottom? The terminology seems a bit weird to me as a thing that cuts a 'slot' I would have assumed to be good at cutting on the side (slots have walls), rather than the end, while the 'end' mill sounds as though it _should_ be good at cutting on the end. But I suppose it is good at 'milling' on the end, rather than 'cutting'? Bugrit, I'll stick with centre-cutting or non centre-cutting, that's at least a single term that can be positive or negative to conjure with.
  1. Smooth finish with v bit on mdf
    By Skydeals in forum General Discussion
    Last Post: 16-10-2015, 10:28 PM
  2. Replies: 4
    Last Post: 21-01-2014, 11:00 PM
  3. Creating .TAP files in Mach3
    By Ahmed in forum Artsoft Mach
    Last Post: 23-11-2013, 09:51 AM
  4. FOR SALE: milling slot cutter 20mm new for sale
    By chalfontcrew in forum Items For Sale
    Last Post: 04-02-2013, 12:18 AM
  5. Creating Local group/club???
    By m.marino in forum General Discussion
    Last Post: 02-07-2010, 11:03 AM
