  1. #21
    Damn this reply box behaviour, now it's recognising spaces but if I insert them higher up the reply it parses them as line feeds and initially ignored them entirely!
    - Nick
    Nick it has happened to me with Chrome I have already sent Lee a PM to let him know that it has reoccurred
  2. #22
    Yes,_check_the_PSU_output_with_the_pins_shorted_th en_remove_shorting_pin,_disconnect_mains_and_conne ct._Then_test.
    - Nick
    All wired up, voltages are good BUT we dont have a white wire (-5v) on the new psu, which we did have on the old one??
  3. #23
    If your PSU doesn't have all the right voltages it isn't the right PSU for the job, you could add a separate -5v fairly easily, but have you asked the manufacturer how much for the correct PSU for the job?
  4. #24
    Quote Originally Posted by jackpat View Post
    I think you need one of the older type ie AT not ATX http://www.ebay.co.uk/itm/AT-PSU-WOR...-/142163387623
    see this at the bottom of the page https://en.wikipedia.org/wiki/Power_...nit_(computer)
  5. #25
    I've pulled a power supply out of an old computer we have lying around, and ive managed to get it wired in. Now when i turn the m/c on the screen is coming up all stripey with a bunch of random symbols/ letters on it. Video card maybe??
  6. #26
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,927. Received thanks 361 times, giving thanks to others 8 times.
    Either the video card, or the video card is getting junk data.
    You're probably better speaking to your board repairers, as now you know what the main problem was, and the machine is now doing something, it may help them track down what has been damaged.
  7. #27
    Just spoken with haas, they thought the processor might have dropped it's guts :( it was only out of the m/c for about of a day and we kept the battery attached though?
  8. #28
    I don't know the machine at all but if and only if it has a dumb monitor ie RS-232 it could be board rate set wrong with showing random symbols. If its a VGA type I take it you have unplugged the monitor and card and refitted.
  9. #29
    Yep i've unplugged & refitted. Any thing else i can check??
  10. #30
    Have you tried asking over on Practical Machinist forum?
    If you're going find somebody online who knows about these machines, then that's the place you're likely to find them.
  1. Haas Hl2 lathe assitance S70 area
    By MAW in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 05-09-2016, 08:09 AM
  2. Haas mini mill spindle ramp up time
    By Hellfire in forum Machine Discussion
    Last Post: 16-05-2016, 10:33 AM
  3. Haas vf-0e 1995
    By jackpat in forum Machine Discussion
    Last Post: 13-05-2016, 11:18 AM
