Page 3 of 8 FirstFirst 12345 ... LastLast
  1. #21
    Quote Originally Posted by 1Jumper10 View Post
    Looks really good. What is your plan for tensioning your pinion gear into your gear rack?
    hi, im going to use spring to hold the pinion against the rack,im using stainless steel to make the bush to pivot the reduction box (scrap prop shaft from a boat).........
  2. #22
    managed a few hours today,
ID:	20012Click image for larger version.
ID:	20013Click image for larger version.
ID:	20014Click image for larger version.
    for the (hopefully)final assembly iv drilled the shaft for the grub screws to bite into and for the pinion gear iv sweated the gear onto the shaft and used a roll pin,which im sure is very stable and wont come loose but now if i have a bearing faiure im going to have to pull the shaft back through the 60t gear and the other bearing,so im not sure iv gone the right way...
  3. #23
    iv had a few hours spare so iv finished the slats for the table....iv used 80x3 flat...
ID:	20047Click image for larger version.
  4. #24
    looking very nice.
    Have you thought of making a scraper/cleaner for the supported rails carriage?
    In the past I have used pot scrubbers ( cheap scotch-brite nock-offs)
    the flat ones .. Like these https://www.youtube.com/watch?v=kAv-pKD0Eug
    profile to suit the rail section.. Green side out. sandwich between to alu plates.
    I soak them in sewing machine oil prior to installation
    Paul
  5. #25
    hi paul,
    iv been thinking about some sort of scraper/gaurd for the linear rails..im ging to put an hour meter on the table so i can get an idea of how long parts last and cost of running.then i can work out if the for instance if the 16mm bearings will last a year and cost x amount and then they become a consumable? Or if its just a bad design and i'll need to rejig it....is plasma dust evil stuff?
  6. #26
    ned's Avatar
    Lives in dublin, Ireland. Last Activity: 18-12-2023 Has been a member for 6-7 years. Has a total post count of 23. Received thanks 1 times, giving thanks to others 0 times.
    Just wanted to say, I've enjoyed reading this thread, I'm trying to learn as much as i can, so your lots of pics approach is great.
  7. #27
    Quote Originally Posted by ned View Post
    thanks for your kind words..i'm back on the cnc today...pics to follow
  8. #28
    ned's Avatar
    cool, following with interest.
    Can I ask you, if you were to guesstimate, how much you reckon the build is going to cost you?
    Speaking in euros, to buy an 8x4 table seems to be around 11 - 12 thousand, so maybe 9 - 10 thousand GBP.
    At the moment I'm trying to familiarise myself with the different mechanical parts of the machine, I'll concentrate on that first and when I've that built, I'll scratch my head and think about the next hurdle, the electronics and software.
  9. #29
    Welcome to the forum Ned. The two are sort of related but when you are ready start a build log and try and get some cad drawings up then ask away.
    Also keep away from kits of electronics as they are never matched.
  10. #30
    ned's Avatar
    Cheers Clive, appreciate the welcome.
    I cant use CAD. I will have to learn. I'm pretty handy with photshop though, so I can illustrate well enough to explain what I mean, hopefully that will do till I learn. Oh its all in front of me... )
    ill bow out of this thread so as not to distract, regards all.
  1. Have you built your own CNC plasma table ?
    By adscnc in forum Opportunities Available & Sought
    Last Post: 15-09-2016, 02:13 PM
  2. Plasma table 4x4 kit and electronics
    By whensparksfly in forum Items Wanted
    Last Post: 27-02-2016, 01:37 PM
  3. 10' x 5' Plasma table design
    By Kerryfisher in forum Plasma Table Machines
    Last Post: 20-02-2013, 09:28 AM
  4. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  5. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
