    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Dont know if anyone else use's these or has seen them before, I have on both counts and they work really well.
    Mrs Roberts has just ordered me some new ones as stocking fillers...yes I have my own stocking at christmas - dont you ?
    This is the best deal:
    1pc NOGA NB1100 Deburring Tool With 10 Blades (BS1010) UK Seller
    There is also a smaller one that fits in a shop apron with front pockets nicely:
    Deburring Tool Noga EO2000 UK Seller
    Noga do a full range of deburring tools, they can get a bit pricey but if your doing allot of manual machining or metal work every day, these can be a real time saver.
    Tom at Oxtools turned me on to these:
    I've asked Santa for the Multi Burr, will have to see what he brings lol !
    http://www.noga.com/deu/
    .Me
  2. The Following User Says Thank You to Lee Roberts For This Useful Post:
  3. #2
    If you dont mind waiting for China post then they are cheaper again:
    NOGA NB1100 Burr Handle With 10pc BS1010 Blades Hand Deburring Tool
    .Me
  4. The Following User Says Thank You to Lee Roberts For This Useful Post:
  5. #3
    Good Call Lee!
    They're a fantastic tool once you get the hang of them,
    - Nick
  6. #4
    No I wear tights ! There are three phases to a man's life -Believing in Santa - Not believing in Santa - Being Santa.
    Seriously, I have a problem with drilling a 2mm thick aluminium plate* with 400 holes 3mm dia. The damn thing comes out like a cheese grater, with the top edge of the hole having a sharp raised lip. A bit of coolant cuts down the problem, but I don't know to get rid of this edge lift or burring. The only solutions I can think of, at the moment, are to slow the drill speed down -or- to redo the process but with a 90 degree chamfer bit, drilling to an appropriate depth i.e. 2.1mm, but that is going to add to the time to do these 20 plates and I certainly ain't deburring them by hand.
    Any suggestions ?
    * the ali plate is probably as soft as poodle poo, I don't know what grade it is.
    Cheers,
    Rob
    BTW Lee - if this could go in a better thread or needs to be a new topic - please shift it. Ta - R.
  7. #5
    Rob, if the surface finish isn't critical, then some form of linisher should work. Even a flap wheel in a drill, or flap disc in an angle grinder, but you need to makes sure you clean it if it clogs otherwise you'll just be rubbing aluminium with aluminium.
    I hate working with generic sheet aluminium, as it's akin to working with butter.
  8. #6
    I have the Noga with the 10 blades and it works like a charm. Having in mind the Eclipse where only one blade is approximately the price of the whole set here. Which for obvious reason i dont use now
    Thanks for that Lee
    £3.71 seems like a bargain to me.
    Regards
    Mike
  10. #8
    Thanks for that Lee
    Regards
    Mike
    I bought 3 of these a year ago for an offer of £8, can't have too many
    I have several including, scrapers and hole deburrers, some are quite old, use them all the time.
  11. #9
    [QUOTE=cropwell;85406
    Any suggestions ?
    [/QUOTE]
    Pic of it would help but you have probably answered your own question. Soooooo many times i see you guys posting about ally cutting problems and nearly all of the problems are because you do not use grades that are machinable. Use the correct grades that ARE machinable. if you don't you will always have these continuing problems of one sort or another.
    Countersink with a very crispy sharp countersink, if the bur is peeling up on one side then you will have a problem of the burr shoving the csk offset and it will be hard to get a neat csk. If the burr is uniform then it should be ok. With very soft materials like this the tendency is to shove the material out of the way as apposed to cutting which itself gives problems even when countersinking because the edge of the hole can not resist the cutting force and the burr wont shear and therefore can also push that burr partially in the hole. It may be an idea to do as mentioned and try a rubbing block to get most of the bur off as possible then csk the hole.
    The right material again will save you all this nonsense you are experiencing.
  12. #10
    Ive had one of these type of tools for a while now and they are excellent.
  1. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  2. Cheap ebay BOB Build:
    By rbs in forum Gantry/Router Machines & Building
    Last Post: 12-02-2015, 02:47 PM
  3. buying cheap from ebay
    By cjpwart in forum Marketplace Discussion
    Last Post: 08-08-2012, 12:17 AM
  4. Bad Seller
    By fidia in forum General Discussion
    Last Post: 05-08-2010, 05:44 PM
  5. Ebay Seller: Savebase
    By Conan257 in forum Marketplace Discussion
    Last Post: 01-08-2009, 09:42 AM
