    Hi Folks,
    We have received a granite surface plate that we ordered from RDG Tools and on unboxing it appears that there is a very fine crack running across the top of the plate. I cannot detect anything running my nail across it, but has anyone experienced or seen anything similar on a granite plate? It is very hard to detect if it is a crack or just an artifact in the natural material. Advice appreciated :)
Name:	granite plate crack.jpg
    The only thing I can think of is dye penetrant testing, that would definitely detect a crack if there is one,
    - Nick
  3. The Following User Says Thank You to magicniner For This Useful Post:
    Also if you suspend and gently strike it with a plastic hammer it won't "ring" cleanly if it's cracked
  5. #4
    Thanks Nick!
    Not sure about this idea as its pretty heavy but I have used crack detector kits in the dim and distant past. Will do a search and see if I can find one that is suitable and fits within our budget ie cheap :)
  6. #5
    Wouldn't accept it my self and send it back. I've never seen crack or defect in any new surface or lightly/correctly used surface plate that is designed to hold any sort of precision.!
  1. How flat is a granite worktop?
    Last Post: 23-03-2017, 11:08 AM
  2. surface grinding / UK
    By dsc in forum General Discussion
    Last Post: 12-09-2014, 06:00 PM
  3. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 05:21 PM
  4. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 06:28 PM
  5. Need advice on surface finish
    By FatFreddie in forum Machine Discussion
    Last Post: 01-05-2010, 01:51 PM
