    I built a Aluminium framed 3axis router a year or so ago and it has been very successfull for us. I mainly machine wood or HD model board (Polyeurethane) for prototyping various product designs for my company. The router uses a small palm router from Makita (RT0700) which is fine for wood and model board. The problem is that the Makita starts at 10,000 rpm and I would like to machine some small plastic and aluminium parts and this is causing an issues with pick up on the tool bits. I would like a spindle that could use HSS bits. Any help appreciated. Simon
    Hi Simon,
    I machine Acetal at about 15k to 24k depending on the speed I'm running at and whether I'm pocketing or trochoidal milling etc. so spindle speed isn't an issue. I'm guessing that you can't run at the feed rates needed for these speeds? What feed rate are you using, what's the max feed rate you can use etc?
    Neil...
    Build log...here
    Hi Neil,
    This is a car badge that I struggled a little with pick up on the tool, it seemed difficult to get enough feed rate. I have no coolant set up which is probably the route cause. I was thinking it would be easier to swap the Makita palm router when needed than introduce adequate coolant.
Name:	P1030419 cropped.jpg
ID:	19733Click image for larger version.
Name:	Finished badges 001.JPG
    The badge was a repair for a friends Micro car.
    If you cant get your machine's feed fast enough for the spindle, have you thought about a brushless DC DIY spindle?
    Neil...
    Build log...here
    Or 1 flute cutter. That halves your feed rate requirement
  1. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  2. Help with DIY spindle (lathe needed)
    By Myken in forum General Discussion
    Last Post: 10-09-2014, 04:20 PM
  3. Spindle encoder ideas needed
    Last Post: 10-08-2014, 01:31 AM
  4. RFQ: WC 2k2W spindle mount needed
    By irving2008 in forum Projects, Jobs & Requests
    Last Post: 17-07-2014, 05:18 PM
  5. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
