  1. #31
    Cheers mate
  2. #32
    Ok, I've got my eye on this thing. Just not sure if it's thick enough.
    Look at this on eBay http://www.ebay.co.uk/itm/331996752740
  3. #33
    There is some bigger stuff on eBay but thinner and was used for bogs, so might be full of scratch and sniff.
  4. #34
    Ok, i bought an old Trespa Athlon lab worktop and man, it's the ducks guts. I didn't realise how solid this is until I started cutting it with a circular saw to get it in the car.
    I've got a 2000x700 piece left to sell if someone wants it. It's a 16mm thick sheet.
    Thanks to all for their input.
  5. #35
    Great! Also just FIY this stuff is incredible for molds, as it keeps very good dimension and has very good resollution when fine cut with small bits. Say you need some gears made or you design sth. Cut it inside the sheet, then pour PU and there you have it.
    Like that: http://lcamtuf.coredump.cx/gcnc/full/
  6. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  7. #36
    Great tip, I'll keep that in mind!
  8. Quote Originally Posted by mondrota View Post
    Should try lifting 12' x 6' x 20mm weighs more than your car. . Lol
  1. CNC Router V1.0 (For Cutting Multiple Materials)
    By biketrialsdave in forum Gantry/Router Machines & Building
    Last Post: 05-08-2017, 03:37 PM
  2. Mini-Mill / Router - Cutting Fluid??
    By Davek0974 in forum Milling Machines, Builds & Conversions
    Last Post: 23-02-2016, 03:19 PM
  3. aluminium profile for cutting bed of router
  4. BUILD LOG: New CNC router 8x4 For Cutting Multiple Materials
    By ciscoeuk in forum DIY Router Build Logs
    Last Post: 03-02-2013, 02:01 AM
  5. WANTED: CNC Mill/Router for Cutting Aluminium
    By kylelnsn in forum Items Wanted
    Last Post: 09-08-2012, 09:54 PM
