Thread: Mach3 licence
    Need some help/advice
    I'm going to buy the mach3 licence which site is the best to download from and secondly does it upset my settings in anyway.
    Quote Originally Posted by Duffman View Post
    Buy from machsupport.com unlesss you particularly fancy buying local. It is just a file you put in the working directory so should not affect your settings.
    https://emvioeng.com
    Happy days that's good to know thanks
    I bought mine from here....https://robocutters.co.uk/products.asp?cat=52...
    It's bit cheaper
    Martin
    Martin when u purchase it do they send a code there or what happened ?
    They send you a link to download and give you a licence code
    You'll get file named Lic.Dat file which you just drop in the main Mach3 folder. Keep Copy of it safe in another location just in case some thing happens to PC harddrive.
    Also good idea to make copy of the XML file your using which as all your settings in same place.
    If you buy from a third party vendor you will need to approach them should you ever need replacement of your license file,
    - Nick
    Got it installed ok and everything is working good thanks guys ����
    Just to extend my thanks to Jim Dingus in Mach3 tech support. After losing my licence file (no! not too many points on it) I got a download reference emailed to me within 24 hours. I had customised the licence via Mach3 support, so they had my details and could re-issue.
    I will not go back to the original licence vendor as my barge pole won't reach Devon.
    Cheers,
    Rob
