  1. #41
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by SparkyLabs View Post
    Well I spoke to jazzcnc today and done some quick thinking.
    I think I will just add digital readouts to my crappy Clarke CMD10 to make life simpler and save for the cc-f1200 HS with 7500 rpm.
    Sent from my phone so mind the autocorrect.
    Have you read the specs. ( re-adjustable free of play trapezoid screws in all axes ) no ball screws and only max 600mm/min rapids
    edit I see that they are optional extra for about £1000
  2. #42
    OK, no not re-read it since I spoke to jazzcnc but yes ball screws are a must. I'll stick with the manual machine and look into the CNC later.
  3. #43
    Sent you a PM sparkylabs, may be of interest ;)
  4. #44
    Is that the one you sent this morning yes read it. Else it's Tapatalk playing up.
  5. #45
    Yep, just the one ;)
  6. #46
    OK. Well I'm still not sure which way to go and had a good chat with jazzcnc this morning which was most helpful. I think if I put DRO's on my current manual mill it will make it useable for prototyping while I learn more about machining and CNC and save up and then buy something decent if it makes sense for light manufacturing.
  7. #47
    Longer spent evaluating and planning is rarely lost time.
    There's a huge range of things that a decent DRO with multiple zeros renders relatively simple on a manual mill.
  8. #48
    Well my whole looking into a CNC mill started with my frustration over the manual machine I use. I looked at DRO's but it became apparent that for some you can start spending hundreds of pounds although I'm a bit confused about the claims of you been able to cut an arc or circle with one of these, typically the ones on eBay have this claim.
    So I didn't want to spend lots of money on the current machine knowing that I will outgrow it and started looking at just getting a CNC. A work colleague found me the proxxon unit however this has turned out to be a bit of a Schrodinger's cat as while the mill exists or apparently exists I will never know if the CNC version exists until I try to order one and see if it actually turns up. My first attempt at getting a quote got me a quote for a manual machine twice in fact this happened. And from this discussion it is clear that there is far more to this than I had realised so I should probably learn about what the hell I am doing and the equipment before buying something that turns out to be no good. I can only but spend the money once.
  1. Thinking about new CAD / CAM
    By Tenson in forum CAD & CAM Software
    Last Post: 13-09-2015, 10:18 PM
  2. Thinking of buying/building machine for PCB milling
    By njh in forum Marketplace Discussion
    Last Post: 11-10-2013, 07:35 PM
  3. thinking about this Syil X5plus CNC Milling Machine with 4th Axis
    By Dellboy in forum Marketplace Discussion
    Last Post: 22-04-2012, 05:52 PM
  4. router jumping position
    By johngoodrich in forum Linear & Rotary Motion
    Last Post: 23-09-2011, 06:31 PM
