Thread: Denford VMC1300 - Rescued
That datasheet should be good enough. The main thing is once you have the machine running, make sure the steppers aren't getting too hot.
Is that a brake assembly on the end of the stepper?
You'll want to check the other stepper motors, as X and Y are often fitted with smaller steppers than the Z.
Regarding the tool holder, if it's been in there for a while, there may be a bit corrosion helping to stick it. You might need to get somebody to push/pull the release lever, while somebody else gives the toolholder a hit downwards with a hammer and block of wood.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
18-01-2017 #2
18-01-2017 #3Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
18-01-2017 #4
I wouldn't swing on anything if it were my mill!
if you remove the casing/cover around the spindle you will probably see a spindle motor connected to the atc spindle via a belt - that's how denford normally do it.
above the atc spindle is a powered drawbar, you need to remove the powered drawbar and then hit the end of the atc spindle with a hammer to release a tool.
all the powered draw bar down is push down on the sprung tip of the spindle atc
The Following User Says Thank You to andy_con For This Useful Post:
19-01-2017 #5
The manual toolchange VMCs have no pneumatics, instead you get a big lever on the side of the head for releasing the tool. I'm assuming underneath the cover, it's the same spindle/drawbar/spring stack as an ATC version, it's just using a lever instead of a pneumatic actuator.
Provided the lever is compressing the spring stack correctly, then all it's likely needing is somebody to pull the lever, while somebody taps the toolholder to give it a bit helping hand to pop it out.
I'd certainly be trying that before going to the extent of stripping of the spring stack and drawbar.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following 2 Users Say Thank You to m_c For This Useful Post:
19-01-2017 #6
I had another go yesterday and all that was needed was a more confident pull on the lever, no need for further stripping or hammers.
22-01-2017 #7
In between doing 'other stuff' in my shed I had a look under the bellows on the y axis and under the guard on the z.
Not much to see under the bellows although the linear bearings and ball screw don't look obviously knackered.
This is the x axis stepper motor,
Its smaller than the z axis stepper. I'm guessing its a NEMA17.
I'm going to google the numbers on the sticker (3100422k) to see if it throws up any clues.
Finally I've had a look at the spindle motor wiring.
My guess is that the heavy gauge wires are power feed. I'm not sue what the pairs of red/blue wires are for. The top pair both have yellow tags labelled 'T'. As far as I can make out the bottom pair has a red tag labelled 22 on the blue wire and a black tag labelled 11 on the red wire. The bottom pair are connected together by a short jumper on the other side of the block.Last edited by Chas Ixion; 22-01-2017 at 02:21 PM.
FOR SALE: Denford Starmill ATC
By andy_con in forum Items For SaleReplies: 1Last Post: 14-02-2016, 10:16 PM -
By andy_con in forum Marketplace DiscussionReplies: 0Last Post: 10-02-2016, 12:01 AM -
FOR SALE: Denford cnc
By john legge in forum Items For SaleReplies: 4Last Post: 17-03-2013, 11:18 PM -
WANTED: Denford Triac
By edwardsjc in forum Items WantedReplies: 13Last Post: 20-08-2012, 08:17 AM -
Denford Starmill
By Phil Gravett in forum Computer SoftwareReplies: 6Last Post: 27-05-2009, 12:05 PM
