    GND's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 12-02-2024 Has been a member for 8-9 years. Has a total post count of 83. Received thanks 3 times, giving thanks to others 11 times.
    Just wondered what types of electrical connectors people like to use on their machines?
    I'm currently rigging up a Z-axis probe, and so want something that is reliable and latched so that it won't come adrift without me noticing. I'm thinking an XLR type connector could be appropriate, but I thought I'd cast the net out to see what forum members use more generally on their machines for the motor drives, limit/home switches and probes. Or is hard wiring preferred?
    Looking forward to hearing any thoughts!
    Graeme
    Hi Graeme,
    I use hard wired for mine, less to come loose and cause problems 😁
    Neil...
    Build log...here
    Hi Graeme,
    My first build used 4 pin xlr's worked well.
    There are some pretty heft stuff available in RS if you are inclined to spend.
    May actually have some male and female 4 pin XLR's left over if you are interested.
    https://emvioeng.com
    I'm using XLR 4-pin for motor connections. Signal connections (limit switches, e-stop, touch plate, etc) use GX16, bought cheap from Aliexpress. That's (I believe) the same connector that the usual air- and water-cooled spindles use with a screwed locking ring for security. Just hold them over a box or tray when you try to refit the fiddly little screw on the side...
    Hardwired. And buy yourself conductive tape from Aliexpress, so motor, limit switch and similar are properly grounded both sides
    GND's Avatar
    Thanks for the feedback, guys - some good suggestions there!
    From this small sample it seems like there's no single solution, and that hardwiring is often chosen. I can certainly see why that might be a good approach. I suppose it depends on the circumstances.
    In my case I am keen to have my touch plate detachable, but obviously there is no room for this connection to be unreliable, else cutter breakages will occur! Hence a good quality latching connector, if you have to use one at all, is essential. I now have a couple of options to investigate further!
    Just curious, Boyan - how do you deploy your conductive tape? Would you mind elaborating?
    Graeme
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,334. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I don't see any reason to do this, just what is the point
    Quote Originally Posted by GND View Post
    Limit switches and servo connection example. may be not "by the book" as it must be using collars bolted to frame, but works fine
ID:	20327 Click image for larger version.
    GND's Avatar
    Thanks Boyan - so essentially shielding?
    If you're just talking about a touch plate why not use 4mm banana plugs? That way the wire can be fixed and put out the way and then plugged in to the plate (or corner plate)
    Neil...
    Build log...here
  1. Which circular connector for spindle
    By ROBCNCAU in forum Spindles & Drive Motors
    Last Post: 19-06-2016, 09:20 AM
  2. Connector for THC ?
    Last Post: 13-06-2014, 02:51 PM
  3. Digitizing probes practicality
    By dudz in forum Probing, Digitizing & Scaning
    Last Post: 04-06-2013, 03:31 PM
  4. Spindle probes for centering
    By maritimesbob in forum Probing, Digitizing & Scaning
    Last Post: 02-09-2012, 11:22 PM
  5. Cable + Connector issues
    By tom3d in forum General Electronics
    Last Post: 09-01-2012, 07:56 PM
