Page 1 of 16 12311 ... LastLast
    Hello everyone, well after making my first router type cnc machine on a budget ive decided to push the boat out and make a milling machine based of a sieg x3 machine.
    The machine is going to be a bit larger than an x3 and hopefully far more rigid.
    linear rails on all axis
    DQ860MA 80V Drivers
    yet to decide on powersupply
    3.0Nm on X and Y nema 23
    4.5Nm on z nema 34
    2.2kw spindle to start with and hopefully BT30 spindle with ATC in the future.
    Pictures to follow:
    Hopefully this is what it will look like: Nearly fully Drawn
    Ears welded up to support the z axis
    Z axis sides, 20mm thick:
    The z axis fully built ready to be surface ground:
    Surface ground and holes drilled and tapped for the ears:
    Just checking the squareness: looks pretty good although this is adjustable on final assembly:
    Mock up:
    Steps machined for linear rails and ball screw supports and nut:
    All holes drilled for linear rails, ball screw supports and the screws which will push them towards the parallel edges:
    Y axis plate machined and holes drilled ready to mount the rails and then surface ground:
    This is just a test piece to check how well the taper locks up: was pretty good with just letting it drop in under its own weight, it would stay in when held upside down, and with a tap of a mallet i wasn't able to pull it apart by hand :)
    Adjustable gas strut to help with the weight of the heavy z axis:
    That's all for now apart from the rails and ball screws that everyone has seen before, material for the bed has been ordered and hopefully will be starting this soon :)
    Hopefully everyone likes the build so far!
    Very nice and definitely will be following this build.
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,915. Received thanks 227 times, giving thanks to others 775 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    There I was at lunch time today browsing through google images at other peoples mill type builds (shortly after reading through JBs x3 conversion thread), i'm keen to have a go at my own mill type, is it obvious yet?
    Then I jump on tonight and I find this gem of a thread! Yea! Perfect timing, cant wait for the rest totts !?!
    .Me
    .Me
    Starting to look very purposeful. Well done. G.
    Thankyou, lots still to do, everytime i think about it theres more to do! :(
    Quote Originally Posted by totts View Post
    Hehe always the way, are you going to fill the z axis column with anything to help with resonance or do you plan for something else, what are you going to use for the base of the machine, my thoughts are a nice slab of steel?
    .Me
    .Me
    I have a nice solid slab of aluminium as shown in the drawing, about 500mm x700mm by 76mm thick so i hope this will be solid enough.
    I was going to fit some of the electronics into the colomn but i am now going to make a stand to house the spindle cooler, electronics, pc and coolant pump, so will probably think about filling the column with something after the z stepper and y stepper is mounted so i know where to fill.
    Trouble is the cost keeps mounting up :( best not to take note and hide the reciepts from the missus hahah
    Good start - almost getting jealous!
    A few general observations...
    Have you seen the BT30 ATC spindles on Aliexpress? If you're happy with 6000rpm then they're not excessively expensive:
    http://www.aliexpress.com/wholesale?...initiative_id=
    PSU - why no decision? A toroidal transformer of around 500VA would be ideal.
    What is the mass of the Z-axis (head, spindle etc) and what are the dimensions of the Z-axis ballscrew? I've made a script to calculate it more accurately, so if you post that information we can make sure the motor you've chosen is the best option. I suspect you may be OK with one of the 3-4Nm Nema 24 motors. The gas strut makes surprisingly little difference if you try to get a reasonable acceleration...
    Correct me if I'm wrong, but it looks like you're leaving the back of the Z column open, so it's a C-shape section not a box? If so then you should defiantly put another plate on the back, as the torsional stiffness of a C-section is very low compared to a box. That's one of the big advantages of putting the ballscrew on the front of the column, not inside - you can have a closed section.
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
