    Bucks's Avatar
    Location unknown. Bucks Last Activity: Has a total post count of n/a. Referred 6191 members to the community.
    Hi, I've just ordered one of these China 3040 4 axis CNC machines from Amazon, I know it's a long way off being a top quality machine, but for the price hopefully it will more than do what we want at the moment, Looks like it's going to be a learning curve & I'm hoping to be able upgrade various parts on it as my CNC experience/requirements grow, we are very limited on room so we are stuck with this sort of size machine & hopefully be even be able to stick it away in a cupboard when not in use!
    Hopefully I've made the right decision in this machine (only time will tell)
    Bucks's Avatar
    I cancelled the above machine & ordered this http://www.ebay.co.uk/itm/182253604089 from Ebay, it's still a Chinese 30/40 machine but it's USB controlled, has a 800w water cooled motor & ball screws , it's the best I can afford as a new machine, as I'm not really into buying secondhand (bit me in the arse that many times in the past) I'm hoping that this machine is a bit higher standard than the cheapest Chinese 30/40 as it's about double the price & looking at the spec it seems to be higher spec/quality than than the others, despite the money side of things, we don't have room for anything bigger so I'm hoping this machine will be ok & see me through my cnc experience! I realise I'm going to have teething troubles with it & have to replace substandard parts on it (hopefully not straight away though) but I don't mind spending the couple of hundred quid here & there to hopefully improve it.
    Bucks's Avatar
    Now I need to work out which cutters I need for cutting/engraving HDPE!
    I realise I will probably need at least a couple of other sized collets.
    Bucks's Avatar
    I had a brain fart yesterday lunchtime! So now busy knocking down a partition wall in my small garage/workshop & pinching back about 3ft of my wife's utility room to give me a bit more room LOL
ID:	20697Click image for larger version.
    Bucks's Avatar
    Sh can't really complain as about 3 years ago the whole lot was my workshop until I gave up half of it for the utility room, so I'm only pinching a bit of it back!
    So you are just taking whats rightfully yours then
    You will need 1/8 3mm and 6mm 1/4 collets for sure. Thats the most used ones. Of course you can choose only the metric, but sooner or later you will see a deal, so better have that 4 collets from start.
    Basically that are the most used bits also. 3mm/ 1/8/ 2 flute spiral bits and 6mm / 1/4/ 2 flute spiral bits.
    Of the 6mm is also best to have 60 degree V cutters for engraving, 2 flute straight bits for general purpose, short and long spiral bits for aluminum or wood cutting. Buy one 12mm and 19mm 2 flute bit 6mm shank, what they call at ebay "bottom cleaning " bit so you could surface with it and for faster material removal / wood/
    You will eventually need some ball nose bits also in all sizes and its good to have 2-3mm diamond shaped cutters for composite materials
    But to learn most of all buy 3mm 2 flute and 6mm 2 flute spiral bits in quantity.
    All of these Carbide is best.
    Bucks's Avatar
    THANKS for the info Boyan it's much appreciated, I'll have a proper read of it later tonight when I've knocked of from moving this wall!
    What are the best makes of bits & are there any makes to avoid or are they all very much the same?
  1. NEW MEMBER: Newbie saying hello
    By Ste202 in forum New Member Introductions
    Last Post: 11-07-2015, 10:57 AM
  2. NEW MEMBER: Not another Newbie!
    By LawcockLD in forum New Member Introductions
    Last Post: 07-06-2014, 11:22 PM
  3. newbie needs help
    By pauley555 in forum Milling Machines, Builds & Conversions
    Last Post: 05-07-2012, 09:48 PM
  4. NEW MEMBER: CNC Newbie
    By packman in forum New Member Introductions
    Last Post: 11-05-2012, 10:07 AM
  5. NEW MEMBER: newbie
    By stevedemicoli in forum New Member Introductions
    Last Post: 31-03-2012, 10:12 AM
