    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    Has anybody got any potentiometer recommendations for Feed Rate / Spindle Speed overrides?
    It's not that I can't find any potentiometers that's the problem, it's the fact I can find too many, so I'm hoping somebody has a suggestion or two. I'm ideally looking for something a bit more industrial, that can take a knock or two.
    Look at the manufacturers of pushbuttons, and they'll often have matching pots, like these.
    https://www.automationdirect.com/adc...ers/ECX2300-5K
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Hi m_c
    Are you looking for a replacement for an existing control or are you building your own control panel ?
    if you go to RS Components for example
    http://uk.rs-online.com/web/c/passiv...potentiometers
    use the filters on the left hand side of the page
    select
    the maximum resistance
    the number of turns - one or multi turn
    type - linear
    mounting type - bush mount
    shaft diameter - 1/4" or 6mm
    element type - Cermet or wire wound
    etc
    by the time you have selected
    the options you require
    you will of reduce the 1500 potentiometrs down to half a dozen at most
    as an example if your looking for a single turn linear 5K potentiometer
    is this what your looking for ?
    http://uk.rs-online.com/web/p/potentiometers/8509514/
    for alternative UK suppliers
    try Rapidonline.com or uk.farnell.com
    John
    Thanks for the suggestions. This is for a new panel.
    I was looking for something like what Ger linked to, but they're bit too expensive to get anything like that in the UK. A bit searching of RS has yielded 502-8637, which is listed as suitable for industrial controls. That's a 10K version, but I may go for a 5K.
    I still need to work out the finer details of wiring the panel, but at least I now have the basic components.
    I have spotted this if it helps 10K Ohm, Single Turn, Panel Mount Speed Pot
    https://www.motorcontrolwarehouse.co...ntiometer.html
  1. Recommendations for Z Axis?
    By samsagaz in forum Gantry/Router Machines & Building
    Last Post: 27-07-2016, 12:46 AM
  2. Potentiometer problem on Chinese 40w laser.
    By andyisko in forum Laser Machines & Building
    Last Post: 13-10-2015, 08:19 PM
  3. Breakout board recommendations
    By GND in forum General Electronics
    Last Post: 15-07-2015, 07:24 PM
  4. Paint strippers - recommendations
    By dsc in forum General Discussion
    Last Post: 12-03-2015, 12:13 AM
  5. CNC Lathe recommendations?
    By UltraMagnus in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 07-09-2011, 08:51 PM
