    Well, stupid phone
    John S -
    Great, thanks John.
    Bit more progress over the weekend. Pretty much finished up my enclosure. A 3rd set of rails for the tops of the doors to be added, and some more polycarb for the windows now that I've measured it right! Some final wiring of lights etc and its about there. I've plastered it in sound deadening and its bolted to both the floor and the wall so very rigid. Will be nice to have a bit less cleaning up to do, the Bridgeport fills the whole shop with chips.
    P
    I've also put a fixing in at the rear direct through the enclosure to the wall to give me a strong point to anchor the column to to beef up its rigidity further. I'm planning to add some adjusting screws to help tramming the mill. How well do the columns line up on these little Chinese mills normally? The mounting faces look nicely ground but I've not done any measurements at this stage.
    P
    The mill arrived so starting stripping that down as well. First time I've bought a brand new machine then proceeded to start throwing half of it away!
    P
Name:	Cabinet Finished.jpg
ID:	20380Click image for larger version.
ID:	20381Click image for larger version.
    Bit of an update. Have started building machine back up.
    P
    Machined the base out to get a bit more Y travel, and generally clean it up. The ways look OK for a Chinese machine but the casting is the typical Chinese effort, bit wibbly wobbly! Had to do some slightly clearancing to the underside of the table where the casting was very uneven to make room for the ballnut mounting. Both axis are now running nicely under Mach3.
    P
    Column also needing machining to straighten up the slot for the ballnut mount which was a little cocked over. That's back in place. Next job is the Z axis motor mounts and ballnut mount and should be somewhere near ready to try some cuts.
    P
    Was going to upgrade the spindle to 5k rpm but I'll need to make some fresh motor mounts for that so might as well get the machine running and use it to make them as a test.
ID:	20780Click image for larger version.
ID:	20781Click image for larger version.
ID:	20782Click image for larger version.
  5. #15
    Aaaarrrrrggggg.
    You have made a fantastic job of the enclose and the rest of the machine and then mount the steppers on 4 pillars ?????????????????????????????????????
    It's a CNC machine tool not a fooking clock !!!!!!!!!!!!!!!!!!!!!!!
    John S -
  6. #16
    Still one of your pet hates then John? :0)
    Nice job on the mill and enclosure.
  7. #17
    I take it you don't like my spindly legs then?! Lol.
    Have to agree they aren't the most manly looking of things, although in my defence as a newb I'm simply copying what ive seen elsewhere. They do seem solid.
    I'll be hiding them with motor covers soon and we shall be rid of the sight of the abominations for ever!
  8. #18
    Quote Originally Posted by Lloyd Barnes View Post
    Thanks for the heads up on this. Have spoken with the motor supplier and done some further research.
    P
    Can I check my understanding. As I understand it (be gentle I'm, still learning this stuff!) running the driver for the NEMA34 at 48v is going to generate a much lower torque. Rather than the 8.7nm its capable of, it's probably going to be running somewhere closer to 4.5-5nm. Speed however shouldn't change? Is that right?
    Ok seen as nobody answered this here goes.! . . . . However first let me point out that suppliers will always want to sell you what they have in stock or highest profit margin they'll never recommend what's best for you if they don't have it on stock.! . . . So if today they have 48V psu's then "This what you need Sir".!!!
    Torque and speed are both proportional to Voltage so both will be affected to some degree. However low voltage affects speed more than torque esp if Motor inductance is high, which is often the case with larger motors hence why 23's are often used.
    The higher the Inductance of the motor the more voltage you'll require to get the same speed/torque than motor with lower inductance. Then we have how the motor is connected to factor into the mix.! . . Bi-polar Parallel or Series wired.?
    Most large motors are 4 wire motors internally wired in series which means they'll require much more voltage than 8 wire motor which can be parallel wired.
    Series wired motor will provide higher torque down low in the speed curve but torque will drop off quickly as the rpm rise. To get higher speeds out of series wired motor will require much much more voltage.
    Parallel wired motors will have lower torque down low but carry it much higher up speed curve and in general give more balanced torque/speed curve using less voltage.
    So in your case if you'd used nema 23 wired parallel with 48V and 2:1 you'd be better off than using series wired 8Nm 34 running on too low voltage.
    Personaly I'd just fit the 34 with 2:1 with what you have got and see how it goes. IF doesn't work out just give it more volts.
  9. #19
    Thanks for the explanation Jazz, learning all the time. First off I have to absolve CNC4YOU of any blame. I watched a lot of videos of builds, then dived in and bought stuff myself. Nothing recommended by them. Fools rush in etc!
    All my motors, NEMA34 included, are 8 wire, wired in parallel. At least I got that bit right then! Lol.
    As you suggest I'm going to fit it and see what happens. If it doesn't work then more voltage will be fired at it.
    I'm hoping to have it running in a couple of weeks so will be interesting to see what it can do. The columns rigid at least as that's bolted at the top to the enclosure frame.
    Thanks for the advice. Appreciated.
  10. #20
    Quick questions folks
    p
    Just modelling up the Z motor mount plate to convert over to a 2:1 belt drive. Are you guys just running a pulley on the unsupported shaft of the stepper motor or are you adding some kind of additional bearing support? I'm conscious the belt is going to need to be pretty tight to avoid backlash, but worried about overcooking it and putting a tonne of side load on the motor shaft.
    p
    What have you chaps done?
  1. Looking into converting my Mill to CNC
    By T0rnado69 in forum Emco Milling Machines
    Last Post: 14-02-2019, 12:46 AM
  2. Hello everyone need help converting a emco f1
    By Ecu-master in forum Emco Milling Machines
    Last Post: 30-03-2014, 08:42 PM
  3. Hi help converting emco f1
    By Ecu-master in forum Milling Machines, Builds & Conversions
    Last Post: 30-03-2014, 12:24 PM
  4. converting pdf to cam?
    By motoxy in forum Computer Software
    Last Post: 28-02-2014, 08:11 AM
  5. Converting sketchup to dxf
    By motoxy in forum Sketchup
    Last Post: 08-07-2012, 12:04 PM
