    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Hey,
    Just found this video of a 4th axis in action, i liked the design he was cutting and also think its a good example of what you could do if you went for a 4th axis !
    Is anyone looking to add a 4th axis or ?
    .Me
  2. Is that a 4th axis or merely a rotary X or Y?
    Quote Originally Posted by BillTodd View Post
    ?????? Sorry can you explain the difference ?
    John S -
  4. Quote Originally Posted by John S View Post
    I was expecting to see 4 axes in motion.
    Here's one I did earlier :dance:
    Ignore the dancing about, the X3 was on a transport stand ready to go to the 2006 Harrorgate show and the castors were not locked down.
    This is another gear but instead of being done on a rotary table or 4th axis this one is just done in X, Y and Z fixed in a chuck bolted to the table.
    The model came out of a CAD parts file off the web as an STL file, programmed in Vectric's Cut3D and cut with a 2mm ball nose cutter.
    The video shows the final clean up pass in the opposite direction to remove some of the cutter marks.
    It could have been a lot better if I had reduced to stepover but as I'd not done one before I didn't want to waste a lot of cutting time if it didn't work.
    Never got round to doing a finer pass gear and some bastard nicked that one anyway [ probably Kip :whistling: ]
    Spiral helicals are one of the hardest type of gear to cut and a one off can take well over a day to cut in a home shop.
    John S -
  6. Quote Originally Posted by Kip View Post
    Yup that's a 4th axis alright...didn't think much to the "action"....it was cutting fresh air!
    When is a 4th axis not a 4th axis...now that is the question :D
    When there's only 3 axes moving! (else I'll claim by engraver is a 9 axis machine - 'cos I've yet to build the other 6! )
    [edit] Just remembered it has a unused 4th axis already so only 5 to build ;)
    Out of interest, is there a general thread for CNC videos?
    Quote Originally Posted by tribbles View Post
    No not as such, we do have a Video Gallery but it hasnt been used that much. I add video's as i find them, your more then welcome.
    .Me
    On the subject of axis'sss whats the diference between 2.5d and 3d ?
    Rough difference.
    2.5 D is where the Z axis drops to a predetermined depth and the shape is produced in X and Y whilst at this depth. X and Y can work together like doing a circle and it's called interpolation.
    Typical example is doing a pocket down to 10mm deep in stages of 2mm at a time.
    3D is where the Z axis is changing all the time as the X and Y are moving, imagine machining the aerofoil section on a plane wing.
    Virtually all machines with a powered Z can do 2.5D and 3D, the difference is in the CAM software to generate the code.
    2.5D is relatively cheap but full 3D starts to get very expensive.
    John S -
  1. Work hold down
    By gorbo in forum Woodwork Discussion
    Last Post: 27-03-2020, 09:15 AM
  2. I am looking for work as cnc operator.
    By krystiankania in forum Opportunities Available & Sought
    Last Post: 13-02-2014, 03:55 PM
  3. RFQ: I am looking for work as cnc operator.
    By krystiankania in forum Projects, Jobs & Requests
    Last Post: 13-02-2014, 03:48 PM
  5. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
