I have a 6040Z 4 axis machine, which has worked well for the past year or so. I decided it was time I controlled the spindle via Mach3, but am having problems.
The control box has JMC 2M542-06 drivers for the X,Y and Z axis and a small generic one for the A axis, with a JP-845 four axis control board. All four axis work great, no problems there, and a Nowforever EN100S2R2B VFD.
The VFD connections I would use are X1 - Fwd control, AN1 - 0-10V for speed contol and COM
I have two different BoB's that I could use;
The JP-845 (image attached) has an unused PWM out socket on the board and what appear to be two relay outputs. The PWM pins are unmarked, and with a DMM I have found two of the pins have a constant 5V across them, while the other two don't seem to do anything. The relay pins are marked No.1, COM, No.2, COM.
No matter how I connect the pins up, I cannot get this to work - the speed of the spindle is not controlled by inputs from Mach3, and the spindle is constantly energised.
I cannot find any info regarding this Bob on the net.
The other is a generic 5 axis BoB (image attached). I have connected this up, and everything works except the spindle control. I have the AN1 0-10V connected to the + pin on the board and the COM to the GND. The X1 (FWD) pin is connected to pin 17 on the board.
Now, this is where I am stuck, and probably being really bone - I don't know if I need the relay jumper on or not and, in fact, whether this is the correct way to do it. I have read several posts where people have linked to this second board, saying they use them, but there are no connection details/
Could someone help me out with this please, I'm going nuts!
14-01-2017 #2
You can find the manual on my dropbox https://www.dropbox.com/s/gfq4isvihn...rd-EN.pdf?dl=0 if it helps.
14-01-2017 #3
Thanks for that, it has a lot more info than the manual I had.
I'm still not entirely sure if I have it connected correctly or not
I have the X1 (FWD) wire from the VFD connected to pin 17
I have the COM wire connected to the GND port on the board
I have the 0 - 10V wire connected to the + port on the boardLast edited by Noddy; 14-01-2017 at 09:32 PM.
14-01-2017 #4
Hi Noddy,
I am sorry that I cannot advise you from experience. I use this board, but only to switch a Kress using an external relay board controlled from a spare output (A or B step, but I can't remember which).
If you have a multimeter set it to volts DC range 0-20v and I would put it on the + and GND to see that you get a voltage up to 10v proportional to the speed setting in Mach3. If that is not so, then you need to look at Mach3 settings. If it is OK then you need to check the VFD connections and parameters.
That multimeter check should indicate which way to look (first).
Cheers,
Rob
15-01-2017 #5
Thanks Rob, I'll give that a go and report back - it's Nanny and Granddad have the kids day today, so won't be able to check until tomorrow, I'll be too knackered to look later lol.
Cheers,
Jim
15-01-2017 #6
15-01-2017 #7
Second board has a bug, Ou need to have both power supplies to use all functions. I used diode bridge and condensator to get 12 volts and phone charger to get power to usb port :)
Poslano sa mog MI 5 koristeći Tapatalk
18-01-2017 #8
BTW I think nominal voltage is 15v not 24v. You will probably need to use one of stepper outputs to start inverter, if it takes 5v then you could directly connect if not you will need relay or something similar.
18-01-2017 #9
A small relay so that you dont burn BOB output
18-01-2017 #10
I have decided that the board is duff, as after having a fiddle with it this morning, the spindle will turn on/off intermittently with nothing being changed.
I have emailed the seller and am awaiting a response.
Bob for spindle control
By Duffman in forum General DiscussionReplies: 8Last Post: 29-12-2016, 02:14 PM -
[HELP] 6 Axis B.O.B with spindle control
By birchy in forum General DiscussionReplies: 7Last Post: 02-10-2014, 12:15 AM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
Advice Needed - Control Panel
By GTJim in forum General ElectronicsReplies: 0Last Post: 18-04-2013, 08:23 AM -
Help with spindle control
By wizzy in forum Spindles & Drive MotorsReplies: 4Last Post: 12-02-2011, 12:51 AM
