Page 3 of 3 FirstFirst 123
  1. #21
    Is there a reason you bought pulleys and belts from different suppliers?
    They do 16mm wide belt and pulley, so these pulley suite your needs,
  2. #22
    Yes it will make a difference it will blow the bloody drives up.!!! . . . . Why do you people give advise without looking and knowing exactly what your telling people to do.? These drives are 50V Max and 48vdc is far too close to limit and when traveling at high feeds the back EMF will fry the drives.
    Kev stick with your current supply for now. I suspect your problem comes from lack of pulses due to high micro stepping with low pulse rate.
    Setting lower micro stepping won't cause stalling and should allow higher tuning of velocity because less pulses are needed.
    3200 is too high and pointless really because most steppers can't resolve higher than this. What it does help with is smoothness but this comes at the cost of high number of pulses which can lower your velocity if can't provide them. If using parallel port with 25Khz then this will most likely be your problem.
    I've seen you mention 10mm but is that width or pitch.? T5 is 5mm pitch not 10mm. So with 20T your linear Pitch will be 100mm per rev.
    Now given your using 3200 pulses per rev and using frequency of 25Khz which is standard frequency for parallel port the max RPM you'll get from your motors is 468.75Rpm.
    This is calculated by taking frequency and dividing by pulses per rev or micro stepping in your case. This will then give Revs per Sec which you times by 60 to give RPM.
    Now take the pitch and times by RPM to get max velocity. So 100 x 468.75 = 46,875mm/min or 781.25 mm/sec .
    So you see if using 25khz with 3200 MS and 5mm pitch with 20T you can't possibly be reaching 800mm/sec.
    Drop the Micro stepping to 1600Ms and your RPM doubles and so does your Max velocity. Lowering Ms won't or shouldn't cause stalling motors. Unless your trying to spin them too fast.?
    By this I mean say if you used same parameters as above but with 400Ms then you could possibly tune the velocity so that the RPM is higher than the motors can handle so get saturated. Above 1500Rpm then steppers motors will struggle depending on load voltage etc.
    Hi jazz, The belts are 10mm wide t5 20 tooth pulley,
    This is a laser cutter running awc608 laser controler,
    The steps it's set to now I can move back and forth nice, but if set them lower they just move 3mm and stall, so not sure if this is through psu needing bit more power, or turning amps up,
    The 48volt psu I got as a ajust screw, if this is turned down to lower volt would it hurt the psu or are they ok,
    Thanks jazz kev
  3. #23
    Quote Originally Posted by kev20009 View Post
    I tried to buy one but it did not go well. The shipping estimate didn't work. I soldiered on, didn't flinch when one pulley plus shipping came to 14.23, typed in all my details, took the PayPal option. A message came up, PayPal not available and they wanted me to start typing all over again. I just don't have the stamina I used to
  4. #24
    Thanks jazz kev
    Ok I see on the controller front and while I can't find the Frequency this controller works at I'm sure it will be more than 25Khz so lack of pulses shouldn't be problem. Still However lowering the MS shouldn't cause stalling motors provided you set it up corrrectly in the controller which might be your issue if not doing this.
    The motors you are using are relatively high Inductance so will require more voltage to spin fast but still with 100mm pitch they should easily reach 500rpm if wired Bi-polar parallel.
    If series wired then this could be your issue because torque drops away quickly as RPM increases and with only 36V may struggle to spin much more than 500rpm.
    Do the Motors have 4 wires or 8 wires.?
  5. #25
    hi jazz 8 wires wired parallel, the only settings that can be set in controller is calibrate the distance moved, table size, homing switches
    I cut square 100mmx100mm and put that in till it gets to right um pulse, which works out at x 15.621760 and y 15.575712
    thanks jazz kev
  6. #26
    yes that's thing that gets me, order a bolt six pound something delivery, order a 3mtr rail same delivery, but got to say it arrives next morning, I pay with paypal but use gest checkout but you got to tick the box,
  7. #27
    Hi Dean,
    It would not be advisable to get the am882 drives and a decent toroidal psu (I guess around 60v, you have more experience..)?
    I see that he had invested a lot in his build but got stuck with some crap drives, and he only needs two of them.
    edit:
    Kev, I told you about the importance of setting up acceleration. Did you get the idea?
    From your controller manual:
    【Max Acc.】: Acceleration when axis making accelerated or decelerated movement. Too a big setting may lead
    to motor losing steps or dither; too small setting may cause slow acceleration and then slow
    processing speed for whole image. For axis with big resistance, such as Y axes corresponding
    with beams, typical setting should be within in 800~3000mm/s2 ; For axis with small resistance,
    such as X axes corresponding with carts, typical setting should be within in 10000~
    20000mm/s2;
  8. #28
    Hi Dean,
    With 100mm pitch then shouldn't need it. 500Rpm isn't diffcult to reach provided theres enough pulses.
    Now what I'm not understanding is the numbers given.? 15.62 for 100mm of movement would suggest close to 205mm pitch with 3200 MS.
    So to me there must be ratio going on somewhere.? . . . or the Belts are not T5.?
  9. #29
    edit:
  10. #30
    Hi Dean,
    edit:
    20000mm/s2;
    Yes all the settings in there are ok and as been altered to suit, all these do is if your cutting then it moves to the next cut, it accelerate to fast and lose steps, or to slow moving to next cut, the speed settings are when your in the layers, as fast for engrave slow for cut,
  1. 10mm belt and nema 23
    By kev20009 in forum Belt Drive, Pulleys & Timing
    Last Post: 27-01-2017, 10:52 AM
  2. eBay Nema23 Stepper mounts
    By Slixxor in forum Gantry/Router Machines & Building
    Last Post: 05-06-2016, 04:02 PM
  3. Anyone have a UK source for open ended 10mm T5 Polyurethane belt
    By cweeks in forum Linear & Rotary Motion
    Last Post: 19-03-2016, 08:43 AM
  4. RFQ: RFQ Nema23 stepper mount
    By r0bsk1 in forum Projects, Jobs & Requests
    Last Post: 15-02-2014, 01:16 PM
  5. DIY Nema23 Motor Mounts
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 23-08-2009, 05:08 PM
