Thread: GH1440 Lathe Bed Conversion
10-03-2017 #30
Em...
I did mean when the servo is in-position, ie stopped.
At that point there is no dither.
Of course, if you try to move it off-position, it then activates and tries to get back into position.
I think all manufacturers make servo drives in to multiple kW or more.
Mine is 2.5 kW continuous.
Much bigger ones are available for not much more money.
30 Nm peak, 10 Nm cont.
Belt drive at 1:3, with HTD8 profile belts, 30 mm wide, taperlock pulleys.
So 90 Nm at the spindle.
The motor mount is a frame, from 30x40mm tool steel bars, and the motor is hard mounted to a steel plate 2 cm thick.
Motor is on top of HS, so heat does not distort spindle (grow it).
I use step/dir with a csmio-ip-s controller
+, enc, mpg, extra io addons
Stepper and Drive sizing for Lathe Conversion
By Robotwizard in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2016, 01:38 AM -
9x20 lathe conversion, pointers wanted
By Stupoty in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 31-12-2014, 08:40 PM -
Sieg mini lathe cnc conversion need help
By diddly in forum Sieg LathesReplies: 0Last Post: 20-12-2014, 10:53 AM -
Seig C4 Lathe CNC conversion
By njhussey in forum Sieg LathesReplies: 1Last Post: 11-04-2014, 06:40 PM -
Micro lathe Zero backlash* conversion
By Jonathan in forum Lathes, Lathe Rebuilding & ConversionsReplies: 14Last Post: 22-09-2012, 10:56 PM
