Thread: Newbie needs CNC advice
06-02-2017 #24
Buck's you'll do well to listen to Clive he's trying to help you not feed you full of Shit like some on here are doing regards these Cheap chinese machines.
They will let you down and they will require maintenance in short period of time. All this talk of upgrading etc is rubbish because you can't make Silk purse out of sows Ear and that's what you buying with these machines.
Also Mach3 running from Laptop with parallel port is at best lottery, some work, most don't. It's also got nothing to do with the Frequency and everything thing to do with Voltage and power management. Also You CANNOT use Parallel port to USB converter and don't let anyone tell you different.
There are Special Devices like UC100 which are Motion control devices which go between the parallel port but there are not converters in the conventional sense.
The simple fact is these Chinese machines are OK for learning but they will break down and will require maintenance within short period of time.
If you buy one with the intension of using as learning tool and don't expect the world then will be fine. If your wanting to do high quality work in difficult materials then forget them they will disappoint you.Last edited by JAZZCNC; 06-02-2017 at 11:15 PM.
BUILD LOG: Hi newbie looking for advice
By bluebug in forum DIY Router Build LogsReplies: 13Last Post: 30-08-2016, 11:41 PM -
Newbie hoping for acrylic advice
By Red_Stafford in forum New Member IntroductionsReplies: 12Last Post: 25-06-2016, 07:11 PM -
RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
By alixus in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-05-2015, 02:39 PM -
Which controller and motors? Newbie advice please
By Nealieboyee in forum Motor Drivers & ControllersReplies: 14Last Post: 16-10-2012, 02:56 PM -
newbie need advice on cnc machine to purchase? routoutcnc machines any good?
By wyndham in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 27-05-2011, 08:54 PM
