Page 10 of 42 FirstFirst ... 8910111220 ... LastLast
  1. #91
    Very nice.
    What type of material is SRBP?
    Sent from my Pixel XL using Tapatalk
  2. #92
    Very nice work. I enjoy following your progress and the quality work you are doing.
  3. #93
    Cheers, slow progress but progress none the less!
    I'm a bit worried that my bearings in the spindle are on the way out, which is a bummer as its not that old. Can't feel any play but just towards the end of the second piece it makes some very unpleasant noises when cutting until you tweak the rpm out of what I assume is a resonance band. Wasn't doing it before.... I might have to delay the purchase of more materials next month to put the money into a new spindle instead and I had just spent hours getting the tram perfect!
    Looking at this combo on ebay at the moment, I guess I could do with a new VFD either for the new machine or to sell with the old one. http://www.ebay.co.uk/itm/260626018545
    Quote Originally Posted by 1Jumper10 View Post
    Very nice.
    Synthetic-resin-bonded-paper - phenolic resin boards, basically a generic name for tufnol kite type material. In larger sizes it's not exactly cheap (that 300x600x8mm sheet was about £30 iirc) but it's got good machining characteristics, is very dimensionally stable, accepts a thread nicely and has very low water absorption which is a plus when using coolant.
  4. #94
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Yes that show the difference between the crap vfd and the good one with the two pics side by side
  5. #95
    I bought my spindle from the same seller. Note that the spindle earth is not connected, at least in mine it was not. Also, I went for a quality VFD instead of buying that Hy. I am using Modbus and the Hy, while they call it Modbus, does not talk Modbus. If I were you, I'd buy the motor, but would get a different VFD, something of a real brand.
    Here is a bunch of 2.2kW VFD sold by the same shop I bought mine from.
    https://inverterdrive.com/group/AC-I...al&StockOnly=1
  6. #96
    I was interested in modbus actually, not that I know much about it at the moment other than it gives better rpm control - which of those models did you go for in the end? Cheers for the link.
  7. #97
    Little more work today, I need to tidy things up a bit in the man cave so good excuse to get the motor mount plates made - allows me to install the screws and motor mounts to start getting things off my desk!
    10mm eco-cast plate, done in much the same way as the other parts so far:
    First fix:
    Drilled and countersunk:
    Second fix, finished:
    Haven't got all the fixings I need (e.g. no countersunk screws long enough etc) but good enough for a test fit, motors are also placeholders. Motor mounts have 6mm dowel pins for alignment purposes:
  8. #98
    SBRP - that's the first time I've heard that name for phenolic. Got it. Thanks.
    Your build is phenomenal. Well done.
    Concerning a new VFD and MODBUS: I just recently set up a Hitachi WJ200 on the bench. I initially used 0-10v analog signal to control speed but the RPM drifted around somewhat due to electrical noise. It wasn't bad but I wanted to experiment with a digital solution. I was leaning towards MODBUS but not with much enthusiasm; Lots of configuring, several different components, driver's etc. Fortunately the Hitachi has a pulse stream input for speed control. I set up my spindle control in UCCNC to use step and direction output, connected the pulse stream input of the VFD to an axis output on my BOB and a little tuning later had it working very well. 2 wires, no driver's, no adapters and no RPM drift. Just a suggestion.
  9. #99
    Thanks, I'll see if I can find out whether or not the pokeys57cnc can do that... certainly a good option to consider.
  10. #100
    great work very nice , what motor mounts are you using?
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
