Page 23 of 42 FirstFirst ... 13212223242533 ... LastLast
  1. #221
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 13 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    At prices of Tufnol I'd glue it to a 12mm sheet of mdf then you can mill through the whole lot screw wasting any.
    If you have issues with losing 12mm of travel on the Z then you really have issues lol
    Problem is that MDF absorbs fluid and 'pulls' apart.
  2. #222
    Yep, MDF is pretty duff for metalwork, great for woodwork.
    At these prices, has anyone priced up a slab of aluminium?
    Its pretty reasonable in 12-15mm thicknesses.
  3. #223
    Chaz's Avatar
    Oddly, was thinking the same. £86 + VAT + Del for 12mm tooling plate at 650 x 450. Normal plate is still £75.
  4. #224
    Yes, similar prices. So what's the attraction? Is Tufnol easy to skim, I bet it skims like butter and really fast, probably quite messy, though not as messy as MDF and harder?
  5. #225
    Tufnol is a brand name, Kite is their equivalent product. Tends to be a bit more pricey than the generic SRBP... I've been buying attwater brand from ebay.
    As for why it's better than alu, it's probably not really! It does skim very quickly and easily with minimal mess (I skim 0.3mm at 6000mm/s using a single flute 10mm cutter)... I like to cut past the work piece in general so I set a cut through of around 0.2mm which then gets completely cleared out at the next 0.3mm skim.
    The main advantage to my mind is that it's softer than alu so more forgiving of plunging down into it quickly so for drilling/tapping it's quicker. Also if cutting CF/FR4/G10/whatever then the fishtail burrs I use for that wouldn't like cutting into alu below the piece but they don't care about cutting into SRBP.
    Alu can also leave a bit of an upward edge/burr where it's been cut which might mess with your perfect level bed until the next skim. SRBP doesn't leave any burr that I can see.
    Both would be perfectly valid, I just tend to use SRBP for the above mentioned reasons. It is also cheaper than tooling plate... eg a board of 600x400x15mm is £50.46 vs £99.36 for the same size of tooling plate from Alu warehouse (both including VAT). That's half the price... adds up when you consider it's a sacrificial board that your machine will consume over time.
    I used a 12mm board which is a bit cheaper than the 15mm... I think it will be too full of holes before I skim it down to a height that's unusable, so there's probably a balance to be found between over-paying for a thicker board that won't be used to it's potential before becoming too full of holes. Will depend on how big your bed is and how hole intensive your work is!
    It is also worth considering that you don't necessarily need a piece to cover your whole bed, only big enough for the largest piece of work you need to hold down.
  6. The Following User Says Thank You to Zeeflyboy For This Useful Post:
  7. #226
    Thank you Zeeflyboy, you are very helpful and I see your logic. The piece of SRBP that I got has slight burring at the edges from the cut, easily removed with a light touch of sandpaper. I also got the same Attwater brand.
    Edward
  8. #227
    Chaz's Avatar
    I agree with this. The other option as a middle ground might be some good plywood. Ive got some and will use it and see how it goes.
  9. #228
    So re-visted my end plates with the correct size stock this time...
    I also tweaked the designs a little, adding a port for the limit switch wire to the top plate and changed the bottom plate to accept a standard FF12 bearing mount (along with some room for adjustment).
    (correct size!!!) stock:
    First op done and bolted down
    Top side ops done
    Bottom sides:
    And the back section of the Z-axis is looking a bit more complete! Still needs limit switch installing, side plates and seals machining up, then I can move on to the main front plate and tramming plate.
    Good view of top seals:
  10. The Following 2 Users Say Thank You to Zeeflyboy For This Useful Post:
  11. #229
    Chaz's Avatar
    Top side ops done
    Bottom sides:
    Excellent work as usual.
  12. The Following 3 Users Say Thank You to Chaz For This Useful Post:
  13. #230
    It's so beautiful that I think I'm gonna cry! ;)
  14. The Following User Says Thank You to Nr1madman For This Useful Post:
  1. Initial design advise wanted
    By driftspin in forum Gantry/Router Machines & Building
    Last Post: 24-10-2017, 06:55 PM
  2. Initial Design Check Please
    By Gotty101 in forum Gantry/Router Machines & Building
    Last Post: 28-02-2017, 07:53 PM
  3. Critique required on y-axis design.
    By Spedley in forum Gantry/Router Machines & Building
    Last Post: 06-05-2013, 09:17 PM
  4. About to build CNC miller, need design critique please
    By JW149 in forum Milling Machines, Builds & Conversions
    Last Post: 23-04-2012, 09:28 PM
  5. NEW MEMBER: About to build CNC miller, need design critique please
    By JW149 in forum New Member Introductions
    Last Post: 22-04-2012, 07:01 PM
