Page 26 of 36 FirstFirst ... 162425262728 ... LastLast
  1. #251
    The only way I can think of doing it is to get a bit of 15mm and have my part sit in it.
    Then when the vice clamps down, the slight bend in the aluminum locks that part in place. I am talking a tiny tolerance that will not bend enough to cause problems, but enough to grip onto the part.
    I'd model it up but my laptop has crapped out on me. Thanks, Windows.
    Also, looking to add a solenoid valve to the machine to turn the air on and off.
    Fed up with having to reach in and turn it on and off. That and I run the machine and leave it for a bit. If it errors our or finishes the op before Ig et back, would rather it switch off the air.
    12v is what the X6-2200L uses on control board right?
  2. #252
    Here is my idea.
    Block with the case silhouette cut out of it. When the vice clamps down there should be a slight bend in the block resulting in it clamping the part.
  3. #253
    Still relying on your vice...
    Make that piece (except minus those channels you added to allow it to flex inwards) out of something nice and sturdy - either alu or something like SRBP. Add a couple of threaded holes either side to allow clamps to hold it externally, and maybe two threaded holes internally underneath those cut outs. I would also add a zero reference hole (the probe works better determining zero from a hole probe than from an open edge probe), though I would ream it rather than just drill/mill it.
    That then allows you to clamp internally with just a screw and spacer, run your external ops, then switch over to clamping externally with screws and a clamp piece to run your internal ops. Only takes a minute to undo two screws and screw in the other set for switching from internal to external.
    depending on what you are doing operations wise, you can also consider the external clamping from both the ends and the sides to allow you to run different operations with external clamping but it doesn't sound like you'll need to.
  4. #254
    I am tempted just to buy a decent machine vice and do it properly..
    I think it is obvious that I need a better one anyway when I am doing my first op.
    I got to make this easier as I have 30-50 cases to make of each type.
    The X6-2200L has 140mm height between the floor and the gantry.
    Minus ~5mm for a spoilplate/wonky correction.
    Leaves me with 135mm.
    Been looking at this, http://www.ymttooling.co.uk/tuscan-s...hine-vice.html
    117.5mm to the top of the jaws.
    Even if I was to hold parts at the top of the jaws, that is 17.5mm clearance.
    The reason I like this vice is that I could probably make the soft jaws really easily.
    The lower height ones I have seen all have the triangle jaws which I can't manufacture.
    They do sell soft jaws for this but they are £86...
  5. #255
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    This style of vice is lower - https://www.cutwel.co.uk/work-holdin...-machine-vices
    However I've still to find more reasonably priced version.
  6. #256
    I checked them out as like you say they are lower. But they are costly and I can't make my own soft jaws for them
  7. #257
    It seems to the ideal vice for what I'd like, but I'm holding of in the hope Cutwel have a promo on them at some point, or until I find something similar in a 5-6" jaw version.
    You can make anything with the right tools ;-)
  8. #258
    Give Cutwell a ring they will give you good deal. (ask for Harriot Dootson)
  9. #259
    Cutwel had the Gerardi vices on offer in December, I got one. Wish I'd got two. Or thee. Or four
    You can set the Gerardi vice up how you want, it doesn't need to have the angle jaws, you can get them with flat jaws, serrated jaws or whatever you want. It's a modular vice and there's a whole tonne of accesories for them. You've still got the issue of the vice bending your work, and in the case of the Gerardi the angle jaws would cause it to bend quite badly (the angle is there to add downforce for pulling the work down to ensure it clamps true repeatedly).
    A dedicated fixture really is the way to go here IMO.
  10. #260
    What model of those extrusion channel nuts do I need for this X6-2200L?
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
