Page 11 of 36 FirstFirst ... 91011121321 ... LastLast
  1. #101
    Here is an overview of my fog-less system and in video description are mentioned all major details so you can DIY one. A properly made one, i mean. Hope that helps you.
  2. The Following 3 Users Say Thank You to Boyan Silyavski For This Useful Post:
  3. #102
    Any recommendations on bits for fillets?
    Like a round over tool for routers.
    Also looking for alternatives to something like the Haimer Universal 3D Sensor.
    Was looking at Zeeflyboy's link to the TPA2 but need something soonish and cheaper :p
  4. #103
    Does this look about right for this 3 flute roughing bit?
    https://www.shop-apt.co.uk/economy-3...-diameter.html
    I have a feeling that 3000mm/s is too much. Gwizard is saying 1000mm/s.
  5. #104
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    1000/S ? Do you mean 1000mm/min
  7. #105
    Doh
    Of course :p
    Also, not 100% on the 1mm and 2mm. Wanted the single flutes but having to wait. Might as well try these.
  8. #106
    Really struggling with the feeds and speeds for this 3 flute roughing bit.
    Works fine for a few seconds then starts to chatter.
    Guessing it is also a cooling problem?
    Got the mister blowing a lot of air on it, also tried with a bit of water but same problem.
  9. #107
    I have gummed up the roughing bits on more than one occasion when milling ecocast plate... to the extent that I actually had to dissolve the aluminium to get it off the cutters. What feeds/speeds and DoC/step over have you been trying?
    Like I said they are definitely far more sensitive to incorrect speeds and feeds than single or 2 flute, proper coolant/lubrication would widen your envelope significantly.
  10. #108
    Tried 500 and 1000 mm/m at their recommendation of 13000 RPM.
    Only tried 2mm DoC.
    Not sure what to try next.
  11. #109
    removed......
  12. #110
    So it looks like heavy mist/flood works really well.
    The finish quality is really good too.
    Having some odd problem where the Gcode is saying helical down, but Mach3 isn't doing it. It is still running the rest of the code as it should be but ignores Z.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
