Page 35 of 36 FirstFirst ... 2533343536 LastLast
  1. #341
    Thanks Chaz. Sometimes the right job needs the right equipment to get the consistency and overall quality. These units are also now made in the correct material for the job, so anodising is now a realistic option should that path be looked at again.
    Jogara should be given a lot of credit to be frank. He has done pretty darn well considering nearly everything has been stacked against him. 10 out of 10 for bravery and perseverance.
    This the next lot being machined.
Name:	1 - Copy E.jpg
ID:	24564Click image for larger version.
Name:	3 - Copy E.jpg
  2. #342
    Quote Originally Posted by JOGARA View Post
    Been a few months. Thought I would update this car crash of a thread with a little something.
    As some of you have seen already, I farmed out the work. Glad to say that it has gone really well and has actually save a lot of my time and was totaly worth it.
    @JOGARA, a big thank you from downunder where I have thoroughly enjoyed following your thread, and have learnt loads from it.
    Cheers,
    Andy
  3. #343
    Usually these things are die cast but I guess volumes are low?
    Anyway beautiful work spluppit ! Can’t beat shiny fresh cut aluminium.
  4. #344
    Any ideas on how to square the gantry?
    I need to do some pretty accurate circles in a week or so. Just cut a 22mm hole for a carbon rod and the circle is oval...
  5. #345
    Sure that’s not due to backlash?
    Other than improving the backlash situation, the only answer to that is backlash compensation in the control software.
    To square the gantry the best I found was to drill 2 holes for precision dowels in the y axis and butt a precision square up against it. I then run a dial indicator along the edge in X axis, and then loosen the gantry bolts and smack it with a mallet until it’s as square as I can get it. You won’t get it perfect as the gantry isn’t completely flat.
  6. #346
    Could well be backlash.
    I just measured it again and my 22mm diameter is 0.04 under in the Y and 0.14 under in the X.
    It is pretty close but next week I need to do a 190mm diameter hole and close fit a bearing in it.
    Yes I am using a caliper... Need a bore gauge.
    It is not as off as I thought but if I can get it close as possible, would be less nervous about the big part.
  7. #347
    What Zee said although also indicate along the Y also to make sure you have the square square.
    That’s a big bore and a tight tolerance for a machine like that. Good luck.
  8. #348
    You can't measure a bore with calipers and believe that 0.04mm measurement or even the 0.14mm for that matter..!! . . . Only a bore gauge can do that with any accuracy.
    Also, it's not just the gantry squareness you need to worry about, the spindle tram and parallelism of the rails all come into play and I know for sure that these machines are not good enough in either of those areas to machine a bore that size to any decent accuracy.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  9. #349
    Hmm
    Built a new enclosure for the machine. This meant I disconnected the PC and moved it for a sort time while I built everything.
    Put it all back together and now the CNC stutters.
    [edit]
    It looks like turning the backlash toggle off stops this...
    The machine earlier did lose a load of steps though and fked up my part -_-
    [edit 2]
    Now getting that "Is the Xpod inserted OK? it has ceased to respond..." error again god dam it
  10. #350
    Surely if you are looking at a bearing fit , then bore micrometers are what is needed.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
