Thread: 3018 stops after short move
14-09-2020 #1
Hey folks,
Can anyone please help me with this?
I have a 3018 Pro-Metal. The board is a Woodpecker CNC CAMXTOOL v3.4
I ran a job the other day, no problem (engraving acrylic). Now today I tried to run a similar job, in fact its from the same job, just a different profile path. Gcode setting, tool etc all unchanged but now when I try to run it, the machine moves the spindle to X0Y0 (as I set Z0 after XY) then it moves to about X50mm & Y10mm and stops. The Spindle does keep spinning.
This is what the console gives me:
Code:$# < [G54:-30.000,-20.000,-9.200] [G55:0.000,0.000,0.000] [G56:0.000,0.000,0.000] [G57:0.000,0.000,0.000] [G58:0.000,0.000,0.000] [G59:0.000,0.000,0.000] [G28:0.000,0.000,0.000] [G30:0.000,0.000,0.000] [G92:0.000,0.000,-5.400] [TLO:0.000] [PRB:0.000,0.000,0.000:0] ok $J=G21G91X0Y0Z10F500 < ok $J=G21G91X-10Y0Z0F500 < ok $J=G21G91X-10Y0Z0F500 < ok $J=G21G91X-10Y0Z0F500 < ok $J=G21G91X-10Y0Z0F500 < ok $J=G21G91X-10Y0Z0F500 < ok $J=G21G91X-10Y0Z0F500 < ok $J=G21G91X0Y-10Z0F500 < ok G92X0Y0 < ok $# < [G54:-30.000,-20.000,-9.200] [G55:0.000,0.000,0.000] [G56:0.000,0.000,0.000] [G57:0.000,0.000,0.000] [G58:0.000,0.000,0.000] [G59:0.000,0.000,0.000] [G28:0.000,0.000,0.000] [G30:0.000,0.000,0.000] [G92:-30.000,10.000,-5.400] [TLO:0.000] [PRB:0.000,0.000,0.000:0] ok Grbl 1.1f ['$' for help]
GCode is created with V-Carve Pro 6.0
I did try easel but that did exactly the same thing and wouldn't complete any jobs.
Can you attach G-code that is giving you trouble, as well as GRBL settings ($$ command)
15-09-2020 #3
This is the offending Gcode.
Note that I had to rename it to .nc for upload to here, the original is .gcode
21-09-2020 #4
Sorry, I missed this bit.
Here are my machine settings:
Code:$$ < $0=10 $1=25 $2=0 $3=2 $4=0 $5=0 $6=0 $10=1 $11=0.010 $12=0.002 $13=0 $20=0 $21=0 $22=0 $23=0 $24=25.000 $25=500.000 $26=250 $27=1.000 $30=12000 $31=0 $32=0 $100=803.700 $101=792.200 $102=800.000 $110=4000.000 $111=4000.000 $112=1000.000 $120=30.000 $121=30.000 $122=30.000 $130=300.000 $131=180.000 $132=50.000 ok
Opinions Please - You No There's No Short Supply On Here
By CNCKitMan in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 11-02-2017, 07:36 PM -
machine stops when homing
By routercnc in forum General ElectronicsReplies: 10Last Post: 27-03-2016, 05:32 PM -
Best place for hard stops?
By mitchejc in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-11-2014, 06:39 AM -
EXPERIENCE: corkcnc ... a short tale
By purpose in forum Trading Experience & FeedbackReplies: 0Last Post: 29-12-2013, 04:43 PM -
gcode stops mid way can anyone test..
By crossleymarko in forum CAD & CAM SoftwareReplies: 16Last Post: 22-04-2012, 12:45 AM
