Thread: my build
Page 2 of 6 FirstFirst 1234 ... LastLast
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    Quote Originally Posted by Kip View Post
    What is...Be specific...is it the agricultural appearance or the use of bed frame?
    Both !
    .Me
  2. Quote Originally Posted by Kip View Post
    I have no bearing location on mine.....the bearings sit against Al plate as they have no radial loads....a spacer in the middle and a belleville washer and a bolt glued in....Nice glue though ;)
    I can't visualise this... picture needed...
    or angular contact bearings (hard to get in small diameter ID).
    Look for magneto bearings, they are the smaller versions of angular contact bearings
    John S -
    jonm's Avatar
    Location unknown. Last Activity: 19-06-2011 Has been a member for 9-10 years. Has a total post count of 89.
    hi guys
    thanks for input ... fixed gantry to sides today, bottom runner in , all feels pretty rigid
  5. #15
    jonm's Avatar
    going to attempt to grind down screws to 8mm then use skate bearing .. with thrust bearing either side , on evilbay thrust bearings for £1.90 each
    cant find angular contact bearings at 8mm, and magneto bearings are £6 each ....... i am after all scotsman
  6. #16
    jonm's Avatar
    never mind.. soon be time to iron last years xmas wrapping paper....
    and tippex the cards..
  7. #17
    jonm's Avatar
    cheers kip
    bag of bearings arrived from " gap bearings " today...
    will feed three 12mm bearings on to trapeziod screw fix bearings down with theseClick image for larger version.
ID:	712 drill on one end , then attack with grinder... sounds so simple....... we will see
  8. #18
    jonm's Avatar
    worked a treat took the threads of with grinder ....last few mil with a file .......
    threaded end for m8 nut
  9. Quote Originally Posted by jonm View Post
    I am impressed Jon. How did you jig the grinder to control the attack?
  10. #20
    jonm's Avatar
    irving
    done it free hand , went down with the grinder till just the very bottom of the threads were left, then set calipers to 8mm ( screw still turning with drill) and used file to take it down the rest .. checking with calipers took about a hour to do .... happy with the result
    should eliminate endfloat with thrust bearings
