Thread: Running 4 1605 screws
Hi guys not sure if anyone as seen this done, I build a z table for a laser cutter, and tried 4 1605 screws with closed loop belt driven by nema24, put all ball nuts to bottom or top rises smooth go back down, but when it comes back up all screws are out 1 will be top but all others out with bigger gaps than others,
There plenty of these table working, so not sure what screws are used, I now these were overkill but I had 2 so just perchased 2 to match lenth,
Thanks guys for any help. Kev
22-02-2017 #2
Repeat the up/down cycle several times to see if the error increases with each cycle, if it does you have a mechanical problem.
If you mark the screws at the front top with a marker pen and run up and down several times do the marks all come to the front again at the same time?You think that's too expensive? You're not a Model Engineer are you? :D
22-02-2017 #3
22-02-2017 #4
22-02-2017 #5
hi glive just checked and pitch 5 mm on all using calipers, yes checked pulleys, only thing I can think is when I put 2 side by side with the start fron,t thread is high to other match line of thread and the start is quarter way round, I have tried every position but still none match when travel stops, thanks again kev
22-02-2017 #6
Check to see if any of the pulleys are slipping on the screws
22-02-2017 #7
Or it could be the stepper/ servo drive is not connected properly to board. STEP signal could be Rising edge or ??? Lowering edge / what was the exact name?/ edge, which if not right, each movement you will loose 1 step. Which if running large toolpaths you could not even see it, but run short multiple tool paths and all goes out of place. BUt as others said make sure its not the pulley slipping
22-02-2017 #8
The way I read it, is that he is using 1 stepper with a belt connecting 4 screws and the screws are going out of sync.
I think he is using the 4 screws to just lower or higher his bed. (one at each corner)
If that is the case the rising edge thing is nothing to do with it...Clive
22-02-2017 #9
22-02-2017 #10
hi sorry for late reply photos to show,
there is 4 rods and nuts, table taken off to try too get it to work, photo shows rods and belt, and the 2 that im trying is out of sink,
thank you guys for trying to help kev
FOR SALE: For sale - 1605 ball screws & nuts. new unused
By Stressedwoodman in forum Items For SaleReplies: 5Last Post: 29-09-2016, 07:19 PM -
1605/1610 have they sent the wrong ones?
By kingcreaky in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 30-07-2013, 09:22 PM -
1605 ballnuts
By dudz in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 30-03-2013, 09:31 AM -
FOR SALE: THK 1605 Balll screw and Nut
By michael in forum Items For SaleReplies: 1Last Post: 28-07-2011, 08:34 PM
