Page 2 of 2 FirstFirst 12
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 20 Hours Ago Has been a member for 4-5 years. Has a total post count of 1,128. Received thanks 201 times, giving thanks to others 5 times.
    Posh way is to take out the clamp screw and tap the clearance hole a size larger. You can then use a jack screw down the hole to controllably open the slot. On the other hand, I have a chunky screwdriver that has one of those red arrows painted on the tip; inserted carefully you can open the slot enough without unduly loading the gantry and the marks will be in the slot and won't show...
    CrazeUK's Avatar
    Lives in Manchester / Bradford, United Kingdom. Last Activity: 16 Hours Ago Has been a member for 1-2 years. Has a total post count of 43. Received thanks 2 times, giving thanks to others 2 times.
    So an update. Play in mount issue sorted. I managed to get it out. Un bolt the holder from the assembly, and get to the bolts the other side, one of the 2 was totally loose. Problem solved. 👍👌 - best thing. No wedges 😂😂
    Sent from my SM-N930F using Tapatalk
  1. WANTED: WANTED - CNC Milling Machine, complete plug and play solution
    By Dangle_kt in forum Items Wanted
    Last Post: 30-10-2016, 12:31 PM
  2. play in bk1204 end bearing blocks
    By deisel in forum Machine Discussion
    Last Post: 30-07-2014, 08:28 PM
  3. Anyone play World Of Tanks ?
    By Fivetide in forum General Discussion
    Last Post: 10-09-2012, 10:46 AM
  4. Should my Z axis have a little play in it?
    By Philly in forum Gantry/Router Machines & Building
    Last Post: 29-04-2011, 03:28 AM
  5. Play in linear bearings
    By leadinglights in forum Rails, Guideways & Bearings
    Last Post: 01-05-2010, 04:01 PM
