    Alrighty!
    Might be an idiotic buy after all ;)
    So.. current configuration? Should I match peak or RMS settings on the dip switches?
    Have 4amp motors (4nm nema23 from cnc4you)
    If going for RMS setting for the driver I get 3.42A RMS 4.78A peak.
    If going for peak current I get 3.15A peak 2.15A RMS or a slight overshoot at 4.03A peak 2.88A RMS.
    For me this seems like really bad options for maximizing my motors.
    I know the AM882/EM806 have software options for fine tuning current but this driver does not seem to have this.
    So.. what says the experts? :D
    I'd set the drives to 4 amps peak?
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  3. The Following User Says Thank You to Ger21 For This Useful Post:
  4. #13
    Thanks Ger!
    Will try that ;)
  5. #14
    Lives in Plymouth, United Kingdom. Last Activity: 7 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    I would read the data sheet and set the current to something reasonable. That is science.
    Once the machine is running, adjust it so that the motors run at a temperature that is just about as hot as you can comfortably hold, which is around 60C. That is engineering...
    Seriously, stepper motors are designed to run hotter than you might expect. More current gives better performance as long as you do not overheat them. Those current readings are really only a guide or a rough starting point, not absolute limits. Remember to set the stationary holding current to half (usually a dip switch setting) which helps keep them a little cooler while not moving.
  6. The Following User Says Thank You to Neale For This Useful Post:
  7. #15
    This is just what I wanted to hear!
    Thanks!
    I realise why they mark up both peak and RMS current. But it's still misleading when you want a safe maximum ;)
  8. #16
    Thanks!
    Hi Nr1madman,
    What is the verdict on the drives?
    Grtz Bert..
  9. #17
    Quote Originally Posted by driftspin View Post
    Hi Nr1madman,
    Grtz Bert..
    Oh let me get back to you in a couple of months :D
    Im just starting to learn my router.
    What I do know is that they move my motors and I haven't had any issues (yet). Would the machine move faster/cooler/quieter with am882s.. I have no idea!! :)
    I bought 2 drivers first with the plan of buying 2 am882s for my dual motor axis but in the end I ordered 2pcs of 2dm860s more. The first two I got had metal casings. The last two had metal bottom and heatsink but plastic cover :)
  10. The Following User Says Thank You to Nr1madman For This Useful Post:
  11. #18
    I've just got 4 to use on a machine so I'll tell you the difference.!
  12. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  13. #19
    Awsome! Thanks ;)
  14. #20
    Hi JAZZCNC,
    It would like to know too...
    Grtz Bert.
  1. Windows 10, is it better than the rest?
    By magicniner in forum Computer Software
    Last Post: 28-11-2019, 11:04 AM
  2. CNC Project - Guitar Neck (and the rest if I can get away with it)
    By Washout in forum Woodworking Project Showcase
    Last Post: 28-01-2018, 10:45 AM
  3. Higher end Chinese controllers?
    By m_c in forum Motor Drivers & Controllers
    Last Post: 22-10-2016, 10:04 PM
  4. Foot Rest Project and how I did nesting in Fusion 360
    Last Post: 24-09-2016, 11:57 AM
  5. NEW MEMBER: Back after a little rest
    By bogstandard in forum New Member Introductions
    Last Post: 27-02-2015, 07:12 PM
