    Hi Guys
    Been having some issues regarding my Combination Woodworking Machine(Spindle Motor wouldn't start) seem to have sorted it but during inspection i took the Start switch to bit's to check it out, points are goosed so would like a replacement, contacted a Robland Stockist and they want £58 + £8.50 postage for same, is this a reasonable price for what seems to be a relatively simple switch ?. I tried searching for it (Salzer T220) but cumming up short. switch is semi rotary two wires in/two out, normally open and contacts make with rotary motion and the motor starts, switch then returned to N/O position.
    If anyone knows a better description than start switch i might have some chance of finding one @ a better price.
    Regards
    Mike
    Cam switch, something like.... http://www.easyflip.co.uk/CPC_Digita...gue/?page=3517 ?
    Bit confused with your description - I understand you to mean that you rotate the switch to start the motor, then the switch returns to the NO position? - spring loaded? - or - is it simply a two-position on/off switch?
    Hi Doddy
    Yes switch is spring loaded to be normally open, rotate to start the motor, then when motor is up to speed switch returns to N/O.
    Mike
    So, a momentary cam switch....
    http://www.ebay.co.uk/itm/ON-OFF-ON-...25.m3641.l6368
    Though I can't quickly find a single-throw switch, you could ignore the second position.
    Hi Mike,
    You might get some joy here http://www.kempstoncontrols.co.uk/T2...zer/sku/161939 There might be more significant information required. Dunno !
    They are probably worth talking to.
    Cheers,
    Rob
    Doddy/cropwell
    Thanks guys will go for the Salzer T225 as this is the original as fit,i also have one on the other side of the machine for when i am planing, and would like them both identical.
    Regards
    Mike
  1. Motor identification
    By petejw in forum Stepper & Servo Motors
    Last Post: 14-03-2015, 12:02 AM
  2. Motor identification help
    By Clive S in forum Stepper & Servo Motors
    Last Post: 25-09-2013, 06:35 PM
  3. Motor Identification
    Last Post: 14-05-2013, 09:27 PM
  4. PARAJUST VFD part identification
    By asto in forum Motor Drivers & Controllers
    Last Post: 28-04-2013, 10:08 PM
  5. Machine Identification - What Is This?
    By machineage in forum Milling Machines, Builds & Conversions
    Last Post: 18-02-2013, 01:36 AM
