Page 3 of 8 FirstFirst 12345 ... LastLast
  1. #21
    Oh well, one down, one to go....
    The rotary attachment arrived today - totally wrecked as the chuck had broken the shaft that mounts it and was loose in the box, unusable and a complete waste - the box that should have held the chuck was in there so why was it fitted??
    My thoughts were previous customer return item.
    emailed supplier with a photo.
  2. #22
    Oh dear, not good.
    My rotary attachment is still bubble wrapped but mine is the simpler, cheaper unit with no chuck, just a set of stepper driven 3 rollers to hold a glass or bottle by friction.
    Can't see it ever getting used.
    I did see another one of the type you have on a forum somewhere, where the spindle had pulled out of the upright because the bearing was a loose fit but it looked an easy fix if you could get redress off the seller.
    John S -
  3. #23
    This would be an easy fix - re-weld the plate and true up on the lathe but that's not the point :)
    See what they say in the morning.
  4. #24
    Broken weld, if you call it a weld...
    Put the chuck box in though, thats a nice touch...
    Nice wiring....
  5. #25
    JS probably saw my post here on Madmodder - see reply #23
    http://madmodder.net/index.php/topic...html#msg126523
    Oh, and my cable outer also was stripped too far back to use the clamps like yours, but I found that by friction warming the outer by gripping with a cloth and sliding it, I could ease the outer far enough down the wires to get under the clamps (which are too large a diameter to grip, but a bit of the serrated end of a tywrap makes up the gap sufficiently !
  6. The Following User Says Thank You to AndrewMawson For This Useful Post:
  7. #26
    Supplier reply - can i get it fixed locally and how much?
    I guess £50 will cover it :) See what they say.
  8. #27
    Mine ended up £40 under asking price. They've just this morning sent me an eBay message asking if it's arrived and am I happy with it! Considering I told them it arrived broken, sent photos, got a discount, and left them neutral feedback you'd think that they were aware of my opinion by now!
  9. #28
    As this was a package deal, i think the rotary added about £100 over the price of the basic machine so £50 seems reasonable i think.
    They certainly don't keep track of orders very closely it seems in your case ;)
  10. #29
    More like it...
    Ground the bird-sh1t off, turned a bevel on the stub so there was somewhere for the weld to fill, nice heavy fillet, turned the flange true to the shaft, refitted it.
    Also drilled a couple of divots for the pulley screws to locate into.
    I'll also replace the crap allen screws which appear to be M6 but have a socket that fits nothing with some proper M6 ones !
  11. #30
    More like it...
    Good recovery Dave
    It has been said before that this Chinese stuff has to be considered a kit of bits
  1. Please don't push 14A through that PCB !!!
    By Jonathan in forum General Electronics
    Last Post: 05-01-2017, 04:43 PM
  2. FREE: Green/Red/Black 3P push button rocker switches
    By Lee Roberts in forum Classified Ads, Buy, Sell & Swap
    Last Post: 08-05-2016, 07:38 AM
  3. Help with Mach 3 REF all Home Button
    By Kevin1970 in forum Artsoft Mach (3 & 4)
    Last Post: 23-04-2015, 10:54 AM
  4. push down plate,
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 31-07-2013, 11:38 PM
  5. Donate Button
    By Ricardoco in forum General Discussion
    Last Post: 08-09-2011, 10:32 PM
