    Clive S's Avatar
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Ok for all you engineers out there.
    I have two O-rings one id 6mm & 2mm cross section and another id 7mm & 1.5 cross section.
    I have a bore of 10mm and a piston 9.96mm. What size groove do I need in the piston for hydraulic dynamic use (this is for a powered draw bar) the piston will move about 7mm in the bore.
    Hi Clive
    Information should be in there .
    https://www.jameswalker.biz/en/pdf_docs/3-o-ring-guide
    Regards
    Mike
    Clive,
    I design pressure systems up to 30ksi. For up to 15ksi, the starting point is the Parker catalogue:
    http://www.parkerhannifin.ru/upload/...ode5712_en.pdf
    In most cases, imperial o-rings are easier to source but there is always a metric equivalent.
    https://emvioeng.com
  4. The Following User Says Thank You to komatias For This Useful Post:
  5. #4
    Clive S's Avatar
    Mike & George Many thanks for the homework you have provided for me. I have found this as well https://oringcalculator.eriksgroup.com/# but I can't seem to get the answer from it. So I will sit down and bang my head against the wall for a bit
  1. How-To: Feed Rate Calculation
    By Lee Roberts in forum Machine Discussion
    Last Post: 25-03-2020, 04:09 PM
  2. pulse equivelant calculation
    By yasser in forum Gantry/Router Machines & Building
    Last Post: 17-05-2016, 10:10 AM
  3. One ring to rule them all?
    By Rufe0 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2016, 04:15 AM
  4. Simple O-ring calculator.
    By jcb121 in forum General Computing
    Last Post: 26-07-2013, 09:00 PM
  5. how to measure a ring for cnc.
    By crimsonred in forum Probing, Digitizing & Scaning
    Last Post: 27-09-2010, 02:47 PM
