    Just tried out my first bit of gcode posted [boring out a hole] from Fusion 360, using an air cut, and it all worked well except:
    1. Pressing cycle start makes the machine move to machine coords Z zero (i.e. Z home switch)
    2. After cutting out the part it moved back to machine coords X, Y, Z zero (i.e all home switches)
    I'm used to Vectric posting code out which moves the machine to work offset zero and safe Z (e.g. local 0,0,20), which is much more handy than having the machine march off to home somewhere over in the far corner.
    The code posts out G28 (line 6, and last but 2 lines), which is moving the machine to machine zero. Here it is:
    (OP2_SINGLEHOLE_6MM_0P5_300)
    (0.5MM PITCH)
    (T1 D=6. CR=0. - ZMIN=-20. - FLAT END MILL)
    G90 G94 G91.1 G40 G49 G17
    G21
    G28 G91 Z0.
    G90
    (BORE2)
    M5
    M9
    T1 M6
    (6MM_2F_19S)
    S12000 M3
    G54
    M9
    G0 X9.409 Y61.753
    G43 Z15. H1
    Z2.
    G1 Z0.6 F900.
    X9.416 Y61.749 Z0.506
    X9.435 Y61.739 Z0.415
    X9.467 Y61.722 Z0.328
    X9.51 Y61.698 Z0.247
    X9.563 Y61.669 Z0.176
    X9.626 Y61.634 Z0.115
    X9.697 Y61.596 Z0.065
    X9.773 Y61.554 Z0.029
    X9.853 Y61.51 Z0.007
    X9.936 Y61.465 Z0.
    X10.199 Y61.321
    G3 X10.878 Y61.521 R0.5
    X9.122 Y62.479 Z-0.5 R1. F300.
    X10.878 Y61.521 Z-1. R1.
    X9.122 Y62.479 Z-1.5 R1.
    X10.878 Y61.521 Z-2. R1.
    X9.122 Y62.479 Z-2.5 R1.
    X10.878 Y61.521 Z-3. R1.
    X9.122 Y62.479 Z-3.5 R1.
    X10.878 Y61.521 Z-4. R1.
    X9.122 Y62.479 Z-4.5 R1.
    X10.878 Y61.521 Z-5. R1.
    X9.122 Y62.479 Z-5.5 R1.
    X10.878 Y61.521 Z-6. R1.
    X9.122 Y62.479 Z-6.5 R1.
    X10.878 Y61.521 Z-7. R1.
    X9.122 Y62.479 Z-7.5 R1.
    X10.878 Y61.521 Z-8. R1.
    X9.122 Y62.479 Z-8.5 R1.
    X10.878 Y61.521 Z-9. R1.
    X9.122 Y62.479 Z-9.5 R1.
    X10.878 Y61.521 Z-10. R1.
    X9.122 Y62.479 Z-10.5 R1.
    X10.878 Y61.521 Z-11. R1.
    X9.122 Y62.479 Z-11.5 R1.
    X10.878 Y61.521 Z-12. R1.
    X9.122 Y62.479 Z-12.5 R1.
    X10.878 Y61.521 Z-13. R1.
    X9.122 Y62.479 Z-13.5 R1.
    X10.878 Y61.521 Z-14. R1.
    X9.122 Y62.479 Z-14.5 R1.
    X10.878 Y61.521 Z-15. R1.
    X9.122 Y62.479 Z-15.5 R1.
    X10.878 Y61.521 Z-16. R1.
    X9.122 Y62.479 Z-16.5 R1.
    X10.878 Y61.521 Z-17. R1.
    X9.122 Y62.479 Z-17.5 R1.
    X10.878 Y61.521 Z-18. R1.
    X9.122 Y62.479 Z-18.5 R1.
    X10.878 Y61.521 Z-19. R1.
    X9.122 Y62.479 Z-19.5 R1.
    X10.878 Y61.521 Z-20. R1.
    X9.122 Y62.479 R1.
    X10.878 Y61.521 R1.
    X10.679 Y62.199 R0.5 F900.
    G1 X10.415 Y62.343
    X10.333 Y62.388 Z-19.993
    X10.253 Y62.432 Z-19.971
    X10.176 Y62.473 Z-19.935
    X10.106 Y62.512 Z-19.885
    X10.043 Y62.546 Z-19.824
    X9.989 Y62.576 Z-19.753
    X9.946 Y62.599 Z-19.672
    X9.914 Y62.616 Z-19.585
    X9.895 Y62.627 Z-19.494
    X9.889 Y62.631 Z-19.4
    G0 Z15.
    M9
    G28 G91 Z0.
    G28 X0. Y0.
    M30
    In the post processor screen for F360 I tried changing the 'use G28' option to 'no', but this just omits the G28, and looks like it will then just home above the feature just cut.
    Any thoughts to get it to go to work offset zero instead of machine zero ?
    Lives in Plymouth, United Kingdom. Last Activity: 11 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    One option might be to redefine the G28 position to be somewhere more useful/less inconvenient? Mine is over the fixed touchplate to help height setting when tool-changing in the middle of a job. I have a feeling that G28 is always in machine coordinates. What difference to the code does the "no G28" option make? Does it then generate some G0 moves instead?
    GND's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 12-02-2024 Has been a member for 8-9 years. Has a total post count of 83. Received thanks 3 times, giving thanks to others 11 times.
    I have used Fusion for many months now with my CNC router, and I discovered very early on that the G28 operation is complex and confusing if you are using Mach3. The answer however is simple - just turn it off in the CAM options. All works as expected then! I read this somewhere on a forum, along with long discussions as to what it should do, and what it actually does. Dazed and confused, I just turned it off, and I haven't looked back.
    Hope that helps
    Graeme
    how do you go about changing it or turning it of?
    Hi Charlie,
    When you post process the toolpath you get this menu:
    (red box)
    Select G28 - no
    I've also looked into searching the post processor library (green box) and there is another Mach3 PP in there which mentions various features including G28. I'll look into that.
    Hi Neale,
    Here is the code comparison with and without G28:
    1) With G28
    OP3_COUNTERBORE_6MM_0P5_300)
    (0.5MM PITCH)
    (T1 D=6. CR=0. - ZMIN=-15. - FLAT END MILL)
    G21
    G28 G91 Z0.
    G90
    (BORE1)
    ... boring operating in here
    G0 Z15.
    M9
    G28 G91 Z0.
    G28 X0. Y0.
    M30
    ___________________________________________
    2) Without:
    (OP3_COUNTERBORE_6MM_0P5_300_NOG28)
    (0.5MM PITCH)
    G21
    (BORE1)
    G0 Z15.
    M9
    M30
    I've not run the without G28 code on the machine but the last G0 just moves to Z15 above the feature just cut, not the work offset zero. Might be good enough.
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I think you need to edit the F360 post. as a workaround you could just hand edit the file in notepad and change the G28 to a G0 and put the numbers in where you want it to go. Don't quote me though
    In your second example:
    2) Without:
    (0.5MM PITCH)
    G21
    (BORE1)
    I am worried that G91.1 is still active (Incremental Arc Mode but some controllers may not process the .1 suffix correctly and leave you in relative mode, as you no longer have the G90 as in the first example.
    Will
    Z home switch position isn't Z zero, it should be Z MAX
  1. Having a go with F360....
    By Davek0974 in forum Fusion 360
    Last Post: 03-09-2016, 07:37 PM
  2. Found F360's limits I think - complex carving
    By Washout in forum Fusion 360
    Last Post: 13-08-2016, 12:35 PM
  3. End Mill Height/Offset Setting
    By cncJim in forum Tool & Tooling Technology
    Last Post: 05-07-2016, 01:08 PM
  4. Mach4 in production run G52 offset with Sub
    By Lee Roberts in forum Artsoft Mach (3 & 4)
    Last Post: 25-08-2014, 11:53 PM
  5. DXF with tool offset
    By Cube3 in forum CAD & CAM Software
    Last Post: 25-03-2014, 10:54 PM
