    A few years ago I built myself a large router for cutting stand up paddle board blanks (pic bellow) however I have now got the need to start cutting other things so would like to start the process of designing and building a second machine.
    The main thing the machine will be used for will probably be for cutting moulds for various things from aluminium with a high quality surface finnish. The moulds I will be cutting will be fairly large so feed rates are important. (also pictured being cut on a china machine I have been using however in surprisingly surface finnish isn't great)
    At the moment I'm thinking 1220 x 600 cutting area with at least 100mm of useable z travel
    I am thinking or running the gantry down the length of the table rather than width if possible so I can use the machine with full sheets.
    obviously ball screws all round
    then I would like to use the cs-labs cysimo again the same as on my last machine.
    I'm open to suggestions, I would quite like to use ali extrusion again for the build as I'm set up for it and have quite a few bits kicking around however I also have a good amount (from memory) 90x90x2.5 box steel that I could passably use if needed for the build if I need to go the steel route.
    when I can figure what exactly Is going to be best I will have a go at starting to draw it up on cad.
ID:	21212   Click image for larger version.
  1. BUILD LOG: DIY Plasma build - Attempt number 1
    By Gigalith in forum DIY Plasma Build Logs
    Last Post: 13-12-2016, 06:42 PM
  2. WANTED: part number
    By tinshak in forum Items Wanted
    Last Post: 10-02-2015, 10:10 PM
  3. Help With a number of build issues & uncertaintities
    By bigstu67 in forum Gantry/Router Machines & Building
    Last Post: 24-09-2014, 03:54 PM
  4. BUILD LOG: A3 Router Build
  5. Number plate dies and a Sieg KX3 CNC Hobby Mill
    By p4tvw in forum Milling Machines, Builds & Conversions
    Last Post: 14-04-2010, 04:51 PM
