12-04-2017 #1
Hi guys,
I am upgrading the electronics on my G540 driven CNC/Router, and need a little assistance with interface between the AM822 error signal, and the PMDX126 error/e-stop connectors.
On the PMDX 126 BoB, it says use connector J13 as below:
1 GND
2 'K' ( input or machine hold )
3 GND
4 E-Stop ( disables the outputs and relays on the PMDX board )
5 GND
6 Fault ( Fault Input ( Active Low) )
7 ERR- ( External ( Gecko, etc ) drive error input negative
8 ERR+( External ( Gecko, etc ) drive error input positive
9 COM ( Common Terminal for Restart Output )
10 RST ( restart output)
Now the Alarm output of the AM822 is:
Alarm signal: OC output signal, activated when over-voltage, over current,
under-voltage, phase-error and stall-error protection. Output polarity can be
programmable. 30V@100mA
So - I had a look at AM822 provided picture for Open Collector and PNP signal, and it makes no sense to me, they have pulse +, Dir +, and ENA + coming from BoB, then they daisy together Pul-, Dir-, ENA-, to the ALM-, going to a controller ground, with resistors fitted where VCC = 12 or 24, but no resistors if VCC = 5 Volts. Given I am not planning on using the ENA+ signal, I would just skip pluggin in the ENA on both accounts, but Do I then Run the ALM -, and daisy chain them together for the 5 different drivers into one line, and then go to the ERR-, or fault, terminal? Is this Common Cathode connection - anything to do with Active high signal, or is that setup seperately to having a common cathode or anode?
The confusing thing is that the AM822 page has the ALM+ signal, going to the ALARM on the Controller, but also the ALM- going to a ground on the controller. SO should all the ALM+ be in series or paralell and go to the ERR+, with the ALM- link together to say pin 5 GND?
Should the PDMX 126 be setup as ( PNP SIGNAL) or Anode? for the motor connectors, as it would seem either can be done?
Confused as hell!
Nick
CSMIO-IP/S Driving Relays directly
By cropwell in forum CS-Lab (CSMIO)Replies: 10Last Post: 02-01-2017, 01:40 AM -
Which PSU and drivers do I need ?
By eurikain in forum General ElectronicsReplies: 10Last Post: 18-08-2015, 11:44 AM -
not enough current for relays?
By Boyan Silyavski in forum General ElectronicsReplies: 17Last Post: 17-08-2015, 10:05 AM -
FOR SALE: pdmx 107 spindle speed control board
By dazza in forum Items For SaleReplies: 0Last Post: 08-05-2014, 02:58 PM -
question about relays
By frankman in forum General ElectronicsReplies: 3Last Post: 23-01-2012, 07:47 AM
