    Hello All,
    Been lurking on here for a while and picked up so much useful information.
    I'm currently looking to build a 4'x4' router to cut aluminium, wood and plastics.
    My current (very) unfinished scheme looks like so
    My initial plan was to use slaved motors on the x axis but after thinking about homing switches and dropping steps I'm thinking of linking the two sides with a timing belt. More thinking required here though
    I'm a mechanical engineer by background so my main worry about the design and build of this machine is the electronics.
    With this in mind, after putting together the rough scheme for the mechanics, I parked that and my main focus for now is getting the electronics built.
    I'm pretty lucky that through work I have managed to salvaged quite a few parts including this small desktop 3 axis router which I will use to test out the electronics panel. When this all works I can progress to start spending time and money on the mechanics knowing that I have the electronics working.
    I've managed to put together a wiring diagram for what I think I need to do.
Name:	ROUTER WIRING DIAGRAM.pdf
    I'm unsure about what motion controller I should use and which version of Mach. Originally I was planning on using an Ethernet Smooth Stepper with Mach 3 as this seemed like it would do everything I need and is well documented. However I need to do some more research into Mach 3/4 and see what the benefits of 4 are. Also been reading about Pokeys and CSLabs controllers so want to understand how these compare to the ESS.
    Again I have been pretty lucky scavenging electrical components from work for the build of the panel. The drivers, BOB and power supplies for the steppers are standard chinese ebay fare. I'm currently laying the parts out in the box to get a feel for where everything should go.
    Thanks for reading and any pointers or criticism much appreciated.
    George
    Hi george!
    Just a quick question. Are you planning on using 5v psu for the drivers?
    This seems very low...?
    Regards
    Madman
    Damnit!!
    Scrolled to much on the phone :D
    Now I saw the 36v psus hehe
    Hi george!
    Regards
    Madman
    Hi madman,
    5v is to power the breakout board.
    24v for estop circuit
    36v for the drivers and steppers
    The 5v into the drivers is the pulse and direction signals (plus I think I need to add in the enable signal too).
    Regards
    George
    Sent from my EVA-L09 using Tapatalk
    Hi George,
    I wouldn't use the e-stop system to kill the mains power to the VFD, at least not immediately like that. I don't think they like being turned off while the spindle spools down. Instead install a 3 second (say) delay circuit, or leave it connected normally and use the run/stop signal terminals on the VFD control panel to turn it off.
    Hi George,
    Hi mate,
    Thanks for the tip. That output on the pnoz is on a delay. Variable from around 5s to a minute iirc.
    Regards
    George
    Quote Originally Posted by GeorgeW21 View Post
    Hi mate,
    Regards
    George
    Apologies George skimmed the dwg quickly. In that case no problem. Those pnoz units are pricey but have nice features.
    Progress is happening slowly...
    Heres a few shots of the gantry coming together.
    https://youtu.be/Ei3kwjfwMrc
    Nice work George getting close now. Interesting how many people that build CNC machines also play guitar !
  2. Beginner Moving Gantry Build? Read This!
    By Tenson in forum Gantry/Router Machines & Building
    Last Post: 23-05-2018, 05:30 PM
  3. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  4. First build - Mid-scale gantry router design
    By Ellis in forum Gantry/Router Machines & Building
    Last Post: 20-05-2015, 11:43 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
