1. Good Morning All,
    My name is Christian and I am early-retired men.
    My hobbies are DIY CNC Router and Aircraft Copters. My equipment in the workshop is a
    Lathe OPTIturn 320mm x 920mm a OPTImill MF 2Vario, Bandsaw etc.
    I made a CNC Router x301, Y490, Z108 with Nema23 Steppers and a CSMIO/IP-S controller, Mach3 with Gerry's Screen
    etc. My profession is electrician so I have to learn alot regarding metallworking. You know my mother tongue is german so please ignore the typographical errors and grammar.
    Best Regards,
    Christian
    Greeny's Avatar
    Lives in North Yorkshire, United Kingdom. Last Activity: 2 Hours Ago Has been a member for 9-10 years. Has a total post count of 109. Received thanks 12 times, giving thanks to others 8 times.
    Quote Originally Posted by bigtwinch View Post
    Good Morning All,
    Hi Christian,
    Early retirement sounds pretty good
    Do you have any pictures or videos of your previous machine?
  3. Quote Originally Posted by Greeny View Post
    Hi Christian,
    Hi Greeny
    As you requested some pictures
ID:	21435Click image for larger version.
ID:	21436Click image for larger version.
ID:	21437Click image for larger version.
ID:	21438Click image for larger version.
ID:	21439Click image for larger version.
ID:	21440Click image for larger version.
ID:	21441Click image for larger version.
ID:	21442Click image for larger version.
ID:	21443Click image for larger version.
  4. The Following User Says Thank You to bigtwinch For This Useful Post:
  5. #4
    Greeny's Avatar
    That looks like a really nice machine.
    Solid, sturdy & very well put together.
    Nice job :-)
    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 9 Hours Ago Has been a member for 6-7 years. Has a total post count of 604. Received thanks 83 times, giving thanks to others 0 times. Referred 1 members to the community.
    Excellent work on the control cabinet.
    Does your Huanyang VFD actually contain the circuitry for that braking resistor?
    Mine doesn't, and I was under the impression that none of them did. They all have the terminals for the braking resistor, but they don't connect to anything.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Greetings from Switzerland
    By Poshpaws in forum New Member Introductions
    Last Post: 05-12-2014, 05:44 PM
  2. NEW MEMBER: Hello from Switzerland
    By Ians in forum New Member Introductions
    Last Post: 11-08-2011, 06:50 PM
