    I was wondering what people have been using as a NEMA23 mount to use with the BK12/BF12 bearing blocks.
    One option is the ready made MBA12-C that accepts an FK12 for the fixed side.
    Has anyone come up with an alternative of their own? The NEMA23 centerline is at 28.2mm, the BK12/BF12 axis is at 25mm. Therefore all that is needed is a way for the motor to sit 3.2mm below the plane on which the BK12/BF12 are fixed.
    Just to be clear, this mostly applies to a custom Z axis.
    X & Y will usually have their own end plates in place where a motor can be mounted appropriately.
    When my ballscrews come I'll tell you lol ;)
    I bought these
    http://www.ebay.co.uk/itm/2624523999...%3AMEBIDX%3AIT
    and need to mount it to this style mounting bracket
    http://www.ebay.co.uk/itm/2525494066...%3AMEBIDX%3AIT
    according to the drawings there is a 14mm difference between the centre of my nema 23 mount and the centre of the BK12/BF12 bearing blocks.
    Luckily I found a piece of scrap tool aluminium that's been milled flat to 14mm from a commercial printer so I intend to cut it down to make "spacers" for the bearing blocks from solid tool aluminium which should align perfectly.
    I might have enough spare pieces to make a few spacers if you're stuck send us a PM.
  1. 10mm belt nema23
    By kev20009 in forum Belt Drive, Pulleys & Timing
    Last Post: 31-01-2017, 05:19 AM
  2. RFQ: RFQ Nema23 stepper mount
    By r0bsk1 in forum Projects, Jobs & Requests
    Last Post: 15-02-2014, 02:16 PM
  3. BK12 end float?
    By birchy in forum Lead Screws, Nuts & Supports
    Last Post: 20-07-2013, 02:28 AM
  4. BK12 & BF12 bearings
    By mlmSolutions in forum Lead Screws, Nuts & Supports
    Last Post: 04-01-2011, 11:16 AM
  5. DIY Nema23 Motor Mounts
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 23-08-2009, 06:08 PM
