Page 62 of 63 FirstFirst ... 125260616263 LastLast
  1. #611
    When I went round to my mates barn I saw what he meant when he said he pimped the mower out.
  2. #612
  3. #613
Name:	clamps machine.jpg
    Been busy but had a chance to make some clamps
  4. #614
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 17 Hours Ago Has been a member for 9-10 years. Has a total post count of 295. Received thanks 28 times, giving thanks to others 13 times.
    Hope you have plenty of cutters
    Phill
  5. The Following User Says Thank You to phill05 For This Useful Post:
  6. #615
    Haha :D what are you planning on clamping there Mr crazy-clamp? ;)
  7. The Following User Says Thank You to Nr1madman For This Useful Post:
  8. #616
    Nice...clamp clamp!!
  9. The Following User Says Thank You to Nickhofen For This Useful Post:
  10. #617
    My first clamp I made was aluminium extrusion and it flexed when I ran the machine over 2m/min when cutting so I went a little OTT with box section steel and toggle clamps lol.
    They're <£1 a clamp that's why I went so OTT, you only need 4 per part, gives me a clamping range of 15mm-28mm thickness, need to put holes in the end metal plates yet so I can use T bolts to attach and adjust the clamp. Going to use 2 per plate so 4 per "clamp for 8 T bolts in total. Wing nuts for tool free adjustment and speed.
    There's 28 clamps on this cost ~£32 to build I had the box section, the annoying bit was drilling and tapping 112 holes to fir the clamps, box section is 3mm wall thickness. At the moment everything I want to work on is 20-25mm thick although I might make another one to do thinner material, need access to a steel milling machine for that.
    You'll see I already lost one the rubber clamp bits will need to put a new one on, if you use these You should do what I intend to do and drop a nylox nut on instead of the normal one so it won't come loose.
  11. #618
    Works really well only need 4 clamps per part so lot's of redundancy.
  12. #619
    I had to move the machine which meant rewiring so I took the opportunity to replace the linuxcnc with a DDSCV
    Going to add a stop and start button.
    I have a stainless steel controller box I recovered for free but needed to make a new mounting plate.
  13. #620
    f750's Avatar
    Lives in herne bay, United Kingdom. Last Activity: 21-11-2022 Has been a member for 9-10 years. Has a total post count of 13. Received thanks 1 times, giving thanks to others 0 times.
    I have built a machine following this and the Joe Harris build. I am using the same BOB and having read all the way though my question is, I am using a dual ball screws and could you confirm the wiring on the inputs for the limit switches.
    Cheers Tony
  14. The Following User Says Thank You to f750 For This Useful Post:
