    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 31-03-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hello all,
    I've been meaning to make this for a while - it's a laughably simple project (for all but the electronics simpletons like myself).
    So, I'm going to base my circuit on this one:
    http://www.555-timer-circuits.com/flashing-led.html
    ...except I'll be using a 12v PS and one of these instead of an LED:
    R1 and R2 control the speed at which the LED flashes - or rather (I'm hoping) the solenoid will open and close - as it is, the led flashes rather quickly - I'm planning to replace these two resistors with a couple of linear pots so that I can adjust open/close times - any recommendations for pot values I should be looking at..?
    Also, the cap value? As I'm using a 12v supply will I need to change the cap - what difference would a different value make to this circuit?
    Finally, will this work..?! Have I correctly assumed that R1 and R2 are independently controlling open/close times?
    Any advice appreciated..!
    Wal.
    Lives in Marple Stockport, United Kingdom. Current Activity: Viewing NEW MEMBER: Nicola malkin Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,335. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Wal I have a 12V solenoid air valve if you want it give me a shout. I think you might need a fly back diode across it.
    Wal's Avatar
    Cheers Clive,
    I'll drop you an email. You might need to explain the fly back diode to me...
    Wal.
  5. #4
    I would expect the NE555 can not provide enough current to operate the
    solenoid valve without the addition of a high gain power transistor
    like the TIP122
    the 1N4001 across the coil is the flyback suppressor diode
    when the transistor is switched on the diode is reverse biased so it does not conduct
    when the transistor switches off a large back emf is produced
    the diode provides a path for the current to flow instead of
    driving the transistors collector more positive than the positive supply
Name:	NE555 plus Darlington transistor.jpg
    John
  6. The Following User Says Thank You to john swift For This Useful Post:
  7. #5
    Wal's Avatar
    Cheers John,
    I spotted this online earlier:
    http://www.robotshop.com/uk/adjustab...ering-kit.html
    Might do the trick, although the output voltage is 24v as opposed to the 12v the solenoid wants.
    Cheers for the additions to the diagram, I'll post my results if I make one..!
    Wal.
  8. #6
    Cheers John,
    Wal.
    Wal See your email. It is the contacts that are rated at 24v 3A
  9. The Following User Says Thank You to Clive S For This Useful Post:
  10. #7
    Wal's Avatar
    Cheers Clive..!
    That's me being dumb again...! If it helps anyone else reading this:
    The output is the relay contacts RATED at 24V 3A and not outputting anything. ie the relay is just a switch that changes state. So the control circuit runs off 12V and you can run the air valve off 12v through the relay.
    Thanks again Clive!
    Wal.
  11. #8
    Hi Wal
    the Velleman kit should make it easier
    looking at the circuit it runs of a 12V supply - ideal for your solenoid valve (don't forget to add the diode across the coil)
    MK111 kit
Name:	mk111 plus valve.jpg
    John
  12. #9
    Quote Originally Posted by john swift View Post
    John
    The 555 can source or sink up to 200mA, so should be OK to operate most relays directly. The 555 is a useful timer chip, but I tend to use arduinos, especially for really long delays.
    Cheers,
    Rob
  13. #10
    Cheers,
    Rob
    ...but 12V 6.5W is over 500mA, so if he is going to use the solenoid on the picture he needs a transistor, or a small relay in between the valve and the 555. The 555 is OK for small relays but not for solenoids.
  1. NEW MEMBER: First timer
    By bofred in forum New Member Introductions
    Last Post: 01-12-2014, 09:23 PM
  2. EMI Filters, any purpose in a diy control circuit?
    By GTJim in forum General Electronics
    Last Post: 14-03-2014, 11:38 PM
  3. Custom Vacuum Table 'Hold Down' System - piping/valve advice
    By FlightCaseCo in forum Machine Discussion
    Last Post: 16-01-2012, 06:56 PM
  4. TB6560 > Timer > GMFC
    By Theo in forum Motor Drivers & Controllers
    Last Post: 17-10-2010, 06:59 PM
  5. NEW MEMBER: Old timer, still learning, Virginia, USA
    By GerryR in forum New Member Introductions
    Last Post: 13-10-2010, 10:41 PM
