01-05-2017 #1
I owned a Chinese SHG 4040 cnc router. It has been out of my hands and with a new owner for the last three years, when I re-bought it back from him, apart from the hand controller was missing, the spindle gets really hot within about thirty seconds you definitely would not be able to touch the spindle case and holding it would burn your hand, I dont mean warm or very warm, this is really hot.
Is there anything that I could have done wrong? I'v re-lubed the internal bearings. The machine had done no work atall from new since I owned it and the new (now Old) owner said that he had not even switched it on, but he could be telling porkies. It was left in an unheated garage and in a fairly dirty/ rusty state when I collected it from him. (Drove all the way from Ireland to Derby to collect it)
I havn't rewired the machine and connections 1, 2 and 3 on the four pin plug/sockets go to the VFD and pin 4 goes to earth, all looks OK there .
Any ideas anybody, before I go and buy a new 1.5kw 80mm ER16 spindle to replace this one ??
thanks in advance, mike Galway, Ireland
01-05-2017 #2
Daft question. I'm sure you've checked, but it's not a water cooled spindle is it?
01-05-2017 #3
01-05-2017 #4
No it's not water cooled and it's not aircooled with fan assist either, its just a cylinder of steel. I originaly bought it in 2005 so probably before the better cooled spindles we have these days.
It was suggested to me today,. that it is perhaps a 110 volt spindle and that the fella that the machine was with, swapped my good 240 volt one for this 110 volt one, does that sound feasible? is there any way to check if a winding on a motor is 240v or 110v?
02-05-2017 #5
VFD set to 240v out with a 110v spindle, are you allowed top swear on this forum
02-05-2017 #6
02-05-2017 #7
Iv put the parameters right now, the spindle is 110 volts, I had 220 volts set in the output of the VFD and that is why the spindle was getting hot. I have changed the output to 110 volts now and its running cool again
02-05-2017 #8
It doesn't seem like there is any cooling atall on this spindle, it is 80mm diameter about 230 long. It was bought around 2005. I cant see aircooling gaps and its definately not water cooled. This is running fine now and does not get hot but does anyone know if I would be making the right move by getting a 240 volt watercooled one.
02-05-2017 #9
CNC gone wrong
By martythunder in forum General DiscussionReplies: 6Last Post: 16-02-2017, 04:21 PM -
When it all goes wrong
By alboy in forum General DiscussionReplies: 2Last Post: 12-12-2015, 01:16 AM -
What has gone wrong????
By Davek0974 in forum Plasma Table MachinesReplies: 54Last Post: 05-09-2014, 12:25 AM -
Ok, so whats wrong?
By Davek0974 in forum 3D Printing MachinesReplies: 32Last Post: 27-03-2014, 12:19 PM -
Help with 1.5kw Chinese spindle. Wrong plug.
By adamh in forum Generic Chinese SpindlesReplies: 5Last Post: 14-01-2014, 07:36 PM
