02-05-2017 #1
Hi, I want to make my mounting plate for my gantry now.
I'm attaching the gantry to SBR25UU bearings (At least 2 of them per side) the rail will be mounted sideways on.
The gantry will be made of 10cm*5cm heavy duty T slot (Probably with angle steel 3mm on the side with the hiwin rail and ballscrew and underneath the steel will be t nut in for extra strength I will mount the carriages so they don't interfere.
I was wondering what thickness steel should I use to be safe I expect the gantry to weigh a fair bit the supported rail is 25mm so I think weight is not so much an issue for the rail or bearings and I can use 3 bearings if need be (2 are 13cm long) I'm going to cu the rail down but I can leave a bit extra overhang so it doesn't affect my working area if I do use 3 bearings. My z axis is going to be heavy as it's going ot be made from this. I will strip it down and have new supports made from more reasonable sized aluminium but it's still going to be heavy. The ballscrew is a 20mm and ground!, the smooth rods are 25mm with bearings. It weighs like 25kg's at moment hoping to get it down to 10kg with the motor & spindle but we will see.
I bought 8 bearings so have spare if weight is an issue.
I will cad this out I was winging it but I think the gantry needs to done in cad so I don't get it wrong.
e2a I want to be able to mill ply and aluminium looking at a 2.2kw water cooled spindle for a start.Last edited by Desertboy; 02-05-2017 at 08:52 PM.
BUILD LOG: Gantry Aluminium thickness guidance
By dachopper in forum DIY Router Build LogsReplies: 30Last Post: 18-04-2017, 07:35 PM -
CNC Project - Sim Cockpit - Throttle Mounting Plate
By Washout in forum Metalwork Project ShowcaseReplies: 1Last Post: 19-12-2015, 12:07 PM -
RFQ: Mounting Plate
By ferus in forum Projects, Jobs & RequestsReplies: 9Last Post: 26-10-2011, 02:56 AM -
FOR SALE: Isel-automation Flat bed X-Y table with motors and mounting plate
By Vespa Mad in forum Items For SaleReplies: 8Last Post: 27-08-2009, 08:45 AM
