    hi all I am running 1610 ballscrews on my y axis with 3nm nema 23 motors and no gearing, and twin 1610 screws on my x axis with a single 8nm nema 34. my drivers are em806 drivers with a 68v power supply. all axis are on hiwin 20mm rails. roughly what rapid speeds should I be able to achieve with this setup not taking in to account weight of axis etc. thanks all
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 7-8 years. Has a total post count of 470. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    Go to this page:
    https://www.zappautomation.co.uk/ecalculators.html
    Click on 'Critical Speed Calculator' in blue at the bottom.
    That tells you how fast the screws can go before whipping. You didn't say how long they are so or how they're supported so I can't go and find that for you :P
    Thats the big limit on maximum rapid speed - what is of more interest is if you can accelerate up to a max rapid speed in a reasonable distance, but thats a far more complex question. On this forum is a motor calculation spreadsheet which will answer your question, but you'll need to provide it with a lot more information. Look at the thread below for the spreadsheet and discussion on how to use it. Page 3 of my build log details the calculations for my build which sounds similar to your setup.
    http://www.mycncuk.com/threads/1524-...otor-do-I-need
    Now, having said all that, assuming a typical design and weight of gantry ~50kg, you should be able to reach 5m/min rapids without any issues.
  1. Speed limits...
    By Davek0974 in forum Bridgeport Milling Machines
    Last Post: 30-01-2018, 10:20 AM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Speed control
    By Saracen in forum Spindles & Drive Motors
    Last Post: 29-12-2012, 02:18 PM
  4. Adjusting speed with vfd
    By motoxy in forum Spindles & Drive Motors
    Last Post: 24-09-2012, 04:07 PM
  5. Top speed failing after a bit
    By Robin Hewitt in forum Machine Discussion
    Last Post: 12-11-2011, 12:46 PM
