Thread: big budget cnc
    Hello
    I am peter 30 from belguim.
    first of all sorry about the bad english i don't typ it a lot.
    I am thinking of building a cnc and i hope you can help me with the design.
    The idea i have is a machine of about 3000x 1600.
    Why this big ? because i have a small company and i make kitchens ,dressings,TV cabinets etc.
    this way i can lay down a sheet of MDF of melamine and cut the pieces .
    But the thing thats special about the machine is the next thing:
    i want the gantry to be 3000 mm, so basicly a big gantry and smaller X axes then normal.
    i was thinking for the gantry 160 mm high and 80 mm deep.
    is this enough or do i need to make it bigger so it do's not flex?
    Instead of linaire rails i was thinking a strip of steel or alu and then ball bearing rolling on the alu or steel rail.
    the reason why is simple.
    I want to start with a budget machine and later in the future upgrade it with better linaire rails like hiwin etc but for know i don't have the money to spend on expensive linaire rails.
    for now i will use a bosch router but also in the future a spindle.
    For the drive i was thinking rack&pinion module 1 is this enough or do i need to use 1.5 or 2?
    the motors and R&P will be mounted on the rails on top.
    i was thinking to use these motors.
    Nema 23 stepping motor 57BYGH627
    is this strong enough or not?
    i made some drawings in sketchup.
    Sorry for the many questions but i just want to be sure before i start building.
ID:	21903   Click image for larger version.
ID:	21904   Click image for larger version.
ID:	21905   Click image for larger version.
ID:	21906   Click image for larger version.
  1. Budget Power Drawbar
    By needleworks in forum Milling Machines, Builds & Conversions
    Last Post: 17-12-2015, 11:36 AM
  2. BUILD LOG: My Budget CNC Router
    By Nealieboyee in forum DIY Router Build Logs
    Last Post: 14-11-2012, 12:57 PM
  3. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  4. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
