Thread: Y axis
21-06-2017 #1
With the help of a very good friend who built his own CNC
I built one, it's good it jogs up and down perfect, but as soon as I put a G code in and push start, both Y axis do there own thing.More than not the Left Y moves from home but the right one is about 2-3 seconds behind, but this twists the Gantry and it binds. I have to level everything up again
Any body help please,
I'm using Mach3 with stepper motors, I'm very new so my knowledge is limited
Getting desperate.
Andy very nice to see you back on the forum and I hope things have improved with the difficulties you have faced.
It would help if you could put a picture up of the machine with some specs. ie motors, power supply voltage, drivers etc. I will help in any way I can...Clive
B Axis indexing and easy workflow for repetitive cuts 4-axis
By deemoss in forum General DiscussionReplies: 1Last Post: 21-06-2017, 12:34 PM -
BUILD LOG: New build - Steel - 3 Axis initially then conversion to 4 axis.
By Slixxor in forum DIY Router Build LogsReplies: 44Last Post: 29-12-2016, 02:57 AM -
Slaved axis, 2 steppers on Y axis with a PLC4x-G2 ? what about the XP23 connector ?
By pierantoine in forum General ElectronicsReplies: 9Last Post: 23-05-2015, 02:07 PM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
