  1. I have purchased some small limit switches and was wondering how to go about installing/wiring them into my setup. Here are some pics of the insides of my control box
ID:	21959Click image for larger version.
ID:	21960Click image for larger version.
ID:	21961Click image for larger version.
ID:	21962Click image for larger version.
ID:	21963Click image for larger version.
ID:	21964Click image for larger version.
ID:	21965Click image for larger version.
ID:	21967Click image for larger version.
ID:	21968Click image for larger version.
ID:	21969Click image for larger version.
ID:	21970Click image for larger version.
ID:	21971Click image for larger version.
ID:	21972Click image for larger version.
ID:	21973Click image for larger version.
    it looks like it may be possible
    but I would need to see more detailed photos of the 3 axis board
Name:	3 axis board & possible limit switch inputs.jpg
    John
  3. Quote Originally Posted by john swift View Post
    John
    Im at the workshop now, will take some more pics for you mate. Bare with me
  4. Click image for larger version.
ID:	21982Click image for larger version.
ID:	21983Click image for larger version.
ID:	21984Click image for larger version.
ID:	21985Click image for larger version.
ID:	21986Click image for larger version.
  5. Are those pics any good mate?
    yes
    this is good enough to see the ground and 3 switch inputs but not know which input is connected to which printer port terminal via opto-isolators
    since the 2 pin stop connector in this picture
    will be your E-stop
    you only have 4 printer port pins to test to find which 3 are for the X Y Z inputs here
Name:	3 axis limit switches.jpg
    John
    PS
    this looks like it has the various connectors used in your control box
    https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
  7. well we have been doing some investigation, (my controller is usb not parallel fyi)
    I think the axis board is buggered, the x axis works only for a few seconds then stops, but on the screen the marker thingy still moves. I have contacted the ebay seller as to how to resolve this as the etsop button also does nothing at all to either the x,y,z axis the spindle or the software.
    Im thinking of buying a planet cnc mk3/4 board? but seems a bit extreme considering this is a brand new machine
    from this view your control box has a printer port connector
Name:	control box printer port and usb connector.jpg
    other pictures of the inside don't show enough detail to see how the printer port connector is or is not connected to the stepper driver IC's
    to be controlled by the USB port there must be a motion controller of some sort hidden under the PCB - possibly a copy of a a planet cnc board
    just in case you send the box back for exchange
    It will be better not to disassemble it any further
    John
    Last edited by john swift; 22-06-2017 at 11:06 PM. Reason: add ref to possible copy of a a planet cnc board
  9. i agree, I have put the lid back on it. From the reasrch I have done other people who have bought the same machine have tried to use the parallel port with mach 3 but will no luck, they have since used the usb and the usbcnc software. I have sent a message to the seller, im hoping we can come to an arrangement and I buy a genuine planet board as I would of thought that would be the best way forward instead of shipping parts too and frow. Does that sound like a reasonable plan of action? also confused as to why the x-axis isnt playing ball too
  1. Wiring home and limit switches
    Last Post: 18-11-2023, 06:14 PM
  2. Wiring Limit switches to Leadshine MX3660
    By thomashomer1986 in forum Motor Drivers & Controllers
    Last Post: 07-01-2016, 08:05 PM
  3. Wiring limit switches
    By Janste in forum Spindles & Drive Motors
    Last Post: 10-02-2015, 10:37 AM
  4. EMC2 home/limit switches... only acting as limit?
    By vputz in forum LinuxCNC (EMC)
    Last Post: 15-10-2014, 09:51 AM
  5. Limit Switches
    By Leadhead in forum General Electronics
    Last Post: 16-10-2013, 10:41 AM
