Page 16 of 18 FirstFirst ... 61415161718 LastLast
  1. well I have a massive update (well for me anyway)
    actually got the machine to home to 0,0,0 last night. Doesnt look like much but for me this is a massive deal and big step forward to getting closer to doing some actual machining.
    Here is a small vid I sent to my mate, ignore the spazzy commentary lol
    Enthusiastic with CNC stuff but a proper novice so be gentle
    My build blog:
    Chinese 3020t Build
  2. #152
    Well the place you have homed to is machine zero. You then jog to the corner of your part then touch off with x,y and Z this then becomes your work offset G54 where your part is actually located on the bed.
  3. #153
    Keep at it Ravi. One small step and all that, for us novices anyway! :-)
  4. Cheers lads,
    yeah one step at a time andy mate
    cheers clive, I will probably set the machine home to the highest z point and x,y to be the centre of the bed as the parts im going to be making will mostly be fixed down to the tooling plate around the edges, so makes sense to keep the spindle away from part? Or maybe at the rear of the bed in the middle
    My build blog:
    Chinese 3020t Build
  5. #155
    Quote Originally Posted by ravihotwok View Post
    Cheers lads,
    I think you are misunderstanding the difference between machine zero and work zero. You are correct to have the Z home to the top then all z gcode will be negative. its nice to home the machine so that X & Y movements to the work position are +ve.
    The work zero G54 is generally where you set it in CAD. So after you have homed you then move the machine to the Zero in CAD then touch off at that point. Work zero G54 can be anywhere on the table and in a different place every time if you want. The Home position is always in the same place.
  6. Quote Originally Posted by Clive S View Post
    I think you are misunderstanding the difference between machine zero and work zero. You are correct to have the Z home to the top ten all z gcode will be negative. its nice to home the machine so that X & Y movements to the work position are +ve.
    Yeah I may be getting confused, I understand that I need to tell the machine a reference datum ie zero for a part once it is jugged into place, but at the end of the program the machine to stop in a position away from where I am undoing the fixings etc if that makes sense.
    My build blog:
    Chinese 3020t Build
  7. #157
    You can just jog away after the machine has stopped. Or add the park position with a bit of gcode at the end of your file. Or set it up in the CAM post.
  8. Out of all that I understood:
    ha ha, still got a lot to learn mate so bare with me pal
    My build blog:
    Chinese 3020t Build
  9. Right chaps, now I have set the limit switches and got the thing to home.
    Whats the next thing to set up??
    My build blog:
    Chinese 3020t Build
  10. well had a good play with the software until the early hours of this morning, and then this happened
    My build blog:
    Chinese 3020t Build
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
