Page 3 of 8 FirstFirst 12345 ... LastLast
  1. #21
    Moving off steppers and on to the spindle motor:
    I spent this afternoon setting up the inverter and its control in Mach. I found that by fiddling with the PWM base frequency that I could get 100% on Mach spindle control to correspond to 100hz on the inverter (which previously it would not).
    Having sorted this out I turned to pulleys and defined the four motor speeds as pulleys. I then calibrated the spindle speed to a range that I thought would work without me having to move the mechanical variator (Reeves type drive) or even replace it with a single fixed ratio poly-v-belt drive. I reasoned I needed speeds between 150rpm and 4000rpm. However, having run the slowest speed of the motor at the lowest reasonable frequency I quickly concluded that the motor has insufficient torque at this speed.
    So I've decided to use be able to use the variator in two positions giving tops speeds of 2000rpm and 4000rpm with plenty of low-down torque in the lower range setting. I'll be mostly machining cast iron and steel so the lower range will be deployed most of the time.
    As I understand it Mach3 while it's possible to tell Mach3 the spindle speed it cannot change the pulley setting automatically. It would have been nice if one of the four motor speed control relays could have been linked and operated by this feature of the software, but I guess I'm hoping for too much! In any case I'll have to set the variator manually.
  2. #22
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    Quote Originally Posted by Agathon View Post
    [pedant mode] The motor should have the same torque at any speed provided the VFD is not limiting current. It's the lack of gearing that means there is insufficient torque at the spindle[/pedant mode]
    Mach 3 can via Macros. I've never done it, however you can use a Macro that takes the requested spindle speed, and changes gears accordingly. Probably worth having a search for gear change over on the Mach forum.
  3. #23
    I hadn't understood the four contactors for speed were operating a mechanical device, I thought you were using the inverter digital inputs to select four preset speeds.
  4. #24
    I feel your pain. I got the notion that everyone was getting better performance out of stepper motors than me and I now have 3.4's which I drive at 220 Volts. Problem is they run hot and I don't trust them at full tilt which is strangely self defeating. You can't win. I keep thinking servo motors are the way to go but I have always been just one rebuild away from wonderful so I am not convinced. Do you really need mega speeds? What is the max delay, end to end on the table? Is it really a problem?
    I suspect the reason we can't have nice stepper motors is that someone has decided they must all be 200 full steps per rev. I got a Roland mill which had 400 full step/rev motors and it is freakin' amazing.
    You are blessed to have that quick tool release, but I am not so sure about driving the Z through the quill rack. I put a ball screw to drive the Z, a ball screw that has to be released every time I hammer out taper tooling. It's only one M8 cap head but I've already had to helicoil the thread.
  5. #25
    You should have a look at Mach3 Brains, watch this video to get an overview; https://www.youtube.com/watch?v=O8V7dZy02og
  6. #26
    [QUOTE=m_c;92790][pedant mode] The motor should have the same torque at any speed provided the VFD is not limiting current. It's the lack of gearing that means there is insufficient torque at the spindle[/pedant mode]
    While I don't claim any expertise on inverter drives, I've been using them for the last 20 years and my understanding and experience is that torque falls off either side of the nameplate frequency. Modern motors designed for inverters and "vector control" improve the flatness of the torque curve but the reason machine tool manufacturers using this type of drive specify such huge motors is due to the drop-off in torque. As an example, one of the Swiss firms I represent in the UK make a plain lathe of 70mm centre height designed for instrument making and horological work. The spindle is belt driven at 1:1 by a inverter controlled 1.1kW motor. In the past this machine was made with multi-pulley drive with a fixed speed motor of 300W!!!
    You may have provoked me into boring you all with another video! The contactors just control the 4 motor speeds nothing mechanical. The variator (Reedes drive) gives the mechanical variation.
  7. #27
    Is that Reedes or Reeves, the one where the pulley opens and closes so the belt rides up and down ?
  8. #28
    Sorry, yes Reeves.
  9. #29
    Thanks for the empathy - much needed! I think the thing is that most people are building routers with very low friction linear rails and low mass tables/gantries. What I've got here is a beast compared to a CNC router. In fact it's probably one of the lightest and smallest pro CNCs that was built. Since owning this machine I've been looking at other high quality, but old, CNCs with a view to doing the same thing, but these are all massive for the same envelope that the Fehlmann has. A couple of good Deckel CNCs have sold on eBay recently for just over a grand but you're talking about 2-4 tonnes of iron, which I don't have the space or the heart to be involved with. Maybe I'll eventually replace my manual Aciera F4 with a bigger CNC, but for now I'll sit tight.
    You are quite right about the traverse speed. The afore-mentioned Aciera F4 has a rapid of 1800mm/min which has never made me feel like I need to pop the kettle on while it does its stuff. So 2000mm/min is fine on the Fehlmann - if it can do it reliably.
    Having been involved with very high-quality manual machine-tools for a very long time I tend to want a professional solution to a problem. It's been a steep learning curve, but as I see it stepper motors for machine tools are now really an amateur thing. I want this machine to perform as an industrial machine should and I will be using it to produce high precision stuff for my own amusement and for my business (I say business, it's Halcyon-days are behind it and with things as they are at the moment it's a paying hobby, which isn't such a problem as I have another job too). Hence, I am drawn to servo motors. The only problem is I know sweet FA about them!
    I'll see how driving the rack goes. As I said in the vid, this thing is a very high precision thing and I can detect no backlash in the rack. There must be some of course, but it's certainly less than 0.01mm. Fehlmann developed this machine into a 3-axis a year or two later and drove the rack with a servo motor - they seemed to have sold quite a few of these machines and they are still sought after in Switzerland.
    Hammering-out taper tooling is always bad news. Have you thought about making a captivated draw-bar so that it pushes the tooling out as you unscrew it?
  10. #30
    At the end of the day I would be looking to convert an S value in gcode to a combination of inverter speed and contactor selection, does that sound correct ?
    So what is the relationship regarding gcode S value, inverter frequency, contactor selection, spindle output speed equal to gcode S value ?
    If that can be determined then it looks like a Mach3 Brain can be used. If you watch the video linked to above you will see that their example has similarities to your own requirement
  1. Toolbox Refurb - New Handle Fittings
    By Wal in forum Metalwork Project Showcase
    Last Post: 22-09-2016, 10:26 PM
  2. CONVERSION: Sx2 plus cnc conversion
    By Lewywri89 in forum Conversion Build Logs
    Last Post: 30-11-2014, 11:36 PM
  3. RFQ: CNC Myford Conversion
    By Jconway651 in forum Projects, Jobs & Requests
    Last Post: 16-10-2014, 09:52 AM
  4. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  5. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
